Question about Brother XL-3500
Brotherxl3100 when i sew my thread breaks i have tried to use different threads samme problem please help
  • ruthrne Oct 26, 2008
    I have Brothers XL-3100. When I sew, the machine comes unthreaded. The thread does not seem to have been cut. I am an apprentice. This is odd to me. Thank you.
    Problem Solver:
  • 7 Answers
You may be sewing to fast or your tension may be off. Check in side the bobbin casing for any loose thread peices.
Posted on Aug 16, 2009
Hi i have a empisal 550d overlocker . I have difficulty with cotton breaking after sewing for a few seconds. Can you help please ?
Could be the tension is set too high on that particular thread tensioner.
If it is not the tension, then this is the first thing to try (I know, it's painful but 99% of the time takes care of my issue): Remove all the threads from the machine, ALWAYS RAISE the presser foot and then rethread from the beginning. Verify that you are threading each in the "proper" order and that the threadpath for each is correct.
If it is a needle thread, replace with a brand new needle. Try a different brand of thread or spool on that particular threadpath. AVOID old or bargain bin thread. Check to make sure that particular thread is not hanging up on a burr, a sharp spot, or looped in the thread tree, etc. that catches the thread and holds it from advancing through the path.
Serger needle thread breaking sewing discussion topic PatternReview com
Lower Looper Threader Keeps Breaking Thread sewing discussion topic...
Jun 09, 2017 | Sewing Machines
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
The thread continues to break
Install a brand new needle--one that matches the type of thread and fabric you are sewing. If the thread is shredding at the needle, then the needle's eye may be too small for the thread.
All About Needles
Avoid using old or bargain bin thread. Try a different type of thread.
Check that the thread is threaded correctly in the machine and that it is not wrapped around the thread spool or a thread guide. Also, set the upper tension to the midway point, ie the tension could be too tight.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Oct 17, 2016 | Sewing Machines
Top thread keeps breaking
Upper thread breaking is usually a sign of incorrect threading or tension too tight, although there are other possible problems:
Industrial Garment Printers Sewing Machines
When threading the upper thread, be sure to ALWAYS RAISE the presser foot so the thread will seat properly in the tension disks. Avoid old thread or bargain bin thread. If the thread is fraying and breaking at or near the needle eye, then try a different type of needle with a larger thread groove that will protect the thread from fraying on rough fabric. Also, check that the thread is not hanging up on something, ie the slit on the side of the spool where the thread tail is stored.
NMSU Checklist of Common Machine Troubles
Jul 02, 2016 | Brother XL-2600I
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Why Does My Thread Keep Breaking While Sew
Apr 03, 2016 | Sewing Machines
My needle threads keep on breaking, I don't know what to do
  • Check the tension of the upper thread. If it's too tight, the pressure on the thread will cause it to break.
  • Check the thread you are using. If you're using two different kinds (one on top and one in the bobbin) that difference can cause the threads to break.
  • Are you using the proper thread for the job? Using a thin or light thread for sewing heavy fabric can lead to breakage.
  • Are you using the correct needle? Sewing knits with a sharp needle or sewing woven fabrics with a knit or ballpoint needle can also cause the thread to snap.
  • Is your machine threaded correctly? Incorrect threading can be another cause for thread breakage.
I hope this helps.
Mar 04, 2015 | Sewing Machines
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
Thread keeps breaking on my E&R machine. Making bean bag, and started off o.k. but nothing I do now stops thread breaking! HELP
Aug 07, 2013 | Sewing Machines
White model 935 maintenance help
Jul 27, 2013 | White Sewing 935 Mechanical Sewing Machine
My top thread often begins to fray and then breaks while I am sewing
try these suggestions and see if they help
Feb 16, 2013 | Janome 8080 Computerized Sewing Machine
Brother XL-3500 Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
