Bush HW60-1460D error code UMP - Washing Machines
Need help in have a lincoln navigator 2004.. I changed the suspension and the ump air as well.. but the car still don't lift... is the module level have to be with the problem
Did you scan the system to see if any fault codes are in the control modules memory? If not you bypassed the most important step to diagnose this ride control problem.
Nov 02, 2016 | Lincoln Cars & Trucks
My sansuie UMP 1004 do not switch on only blue light flashing.need help please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 04, 2016 | Televison & Video
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Ricoh c2500 sc565 error
could be a number of issues - i would 1st of all clean the thermistors and rest. after this check the belt for any blistering. after this see if the plastic bushings on the heat roller on the belt are clean and functioning. if none of this works id replace the thermistors then the bushings and belt
Oct 15, 2013 | Office Equipment & Supplies
Keeps beeping. won't copy. Error code E000...
Your problems in the fuser unit or main unit.Please chekc the mechanical parts,bearings,bushings.
May 17, 2010 | Office Equipment & Supplies
Loosing ump gutless plugs have 140,000 no codes in comp.
I would definitely do a complete tune up. Plugs, wires, oil change, fuel filter and air filter.
Feb 04, 2010 | 1998 Ford F150 Regular Cab
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
344 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
