Question about Maxi-Cosi Priori
Just bought a maxi cosi priorifix car seat and the handle for the recline is very loose and kind of flappy, however it does work (i.e. the seat moves and locks into the 4 positions) is this how it should be, or is mine broken?
  • Maxi-Cosi Master
  • 1,629 Answers
Good Evening
"Loose and kind of flappy" is not how the recline handle on a PrioriFix carseat should be described - Please contact your retailer with your proof of purchase and ask them to compare it to others in store to check whether yours is different. If it is, they will be able to assist from there.
Posted on May 23, 2011
Lost Maxi cosi recyning rod
Hi
Which model Maxi-Cosi Priori is it?
The original Priori was discontinued some time ago and we can no longer support this product for spare parts or repairs. We would advise that this particular seat is replaced.
The Priori SPS, PrioriXP and PrioriFix carseats are still part of the current range so can be supported for spare parts and repairs. If you visit www.maxi-cosi.com and select which country you're in you'll find a Contact Us tab on the right side of the page where you can click to send your enquiry to the customer care team in your country.
Replacement Recommendation for Older Carseats Carseat Bases
Apr 01, 2014 | Maxi-Cosi Priori
Where can I get replacement belt hooks from? Both of mine have come off my maxi cosi priorifix car seat. Many thanks. Marie
Good Afternoon
The belt hooks for the PrioriFix can be obtained via your local retailer or direct with the customer service department.
To find the customer service department for the country you're in go to www.maxi-cosi.com and select the country you're in, then go to "Contact Us" and you can get in touch with the customer service department where you are for further assistance.
Jul 20, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How so i install my car seat rear facing
Good Evening
In the UK the Maxi Cosi (original) Priori, the Priori SPS, Priori XP and PrioriFix carseats are not for rear facing use. They are only to be fitted forward facing.
May 23, 2011 | Maxi-Cosi Priori
My maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Jan 03, 2010 | Baby Gear
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi xr
You can download the user manual via the link on this page, just below the features listing:
http://www.babycare.nl/maxi-cosi-rodi-black-reflection-2009-p-964.html
Have a look page 3, illustration 10
Hope this helps,
babycare.nl
Erwin de Raad
Jun 03, 2009 | Maxi-Cosi Maxi Cosi Rodi XR 'Phantom'...
Maxi-cosi priorifix - fitting with seat belt
Sure!
Please download the manual via this link.
The instructions are on page 10, paragraph D
http://www.maxi-cosi.nl/media/producthandleidingen/maxicosi/PrioriFix.pdf
With kind regards,
www.babycare.nl
Erwin de Raad
Apr 18, 2009 | Maxi-Cosi Priori
Moving maxi cosi to another car
I assume that you mean the Maxi Cosi Priorifix?
At the top of the leg (that extends to the floor of your car) there is a button (which, if connected to the Isofix points will be red) push this button in as far as it will go and the seat will release from the Isofix points.
I hope this helps.
Jan 25, 2009 | Maxi-Cosi Priori
How to remove the car seat cover
contact the manufacture at
email Consumer Relations at consumer@maxicosi-us.com, or call Consumer Relations at (800) 951-4113.
they can help
Apr 26, 2008 | Maxi-Cosi Priori
Maxi-Cosi Priori Logo
179 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
