Question about Bosch Nexxt 300 Series WFMC2201UC
Have a Bosch Nexxt model#WFMC 3200 UC/01. The machne runs through cyle but drum doens't roll and spin cycle doesn't do anything. Clothes just sit. No error codes but when the repairman came he got an error code E20 and says I need a new motor and it will be $250? Seems like alot of money to invest in a 5 year old unit (though unit only used for past 2 years since it was in a model home). Suggstions?
  • 223 Answers
SOURCE: Bosch nexxt washer is leaking from underneath
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
Posted on Sep 26, 2008
  • 157 Answers
SOURCE: Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Posted on Dec 29, 2008
SOURCE: Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Posted on Jan 01, 2009
  • 27 Answers
SOURCE: put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Posted on Mar 12, 2009
  • 38 Answers
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Posted on Jul 28, 2009
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
Jun 07, 2011 | Bosch WFMC 3200 Front Load Washer
My washer rocks on spin cycle and i have made sure that it is balanced and it is still doing it dramatically. It does not do it when it runs empty.
You need to put in less than 18 lb./ 8kg of clothes in it. It can make vibration if overloaded! If it stil vibrates with small amount of clothes maybe one of the shocks is not mounted or damaged!
Jan 25, 2011 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Washer WFMC3200.
Contact a Bosch technician. You may have to at least pay for a service call.
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
Put front gasket back on
Mar 12, 2009 | Bosch WFMC 3200 Front Load Washer
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
Clothes just don't seem to smell clean
We have the same problem with the 3200, I have run a cycle through with no clothes and adding bleach instead of detergent.
Seems to help some.
Feb 28, 2008 | Bosch WFMC 3200 Front Load Washer
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt 300 Series WFMC2201UC Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
