Question about RCA F32649 32" TV
Rca F32649 32"
The tv continually scans channels, never ending i got into the set up and it keeps scrolling through on it's own
  • 1 more comment
  • beverlymoore Aug 20, 2008
    my RCA floor model continually scans and will not stop. not sure what model
  • mytutin Dec 03, 2008
    Ok I have the same problems..channels flipping non stop. I read your solution and I am going to do it myself they are asking $150. One question how will I know which is the up and down switch when I open the TV? help please...
  • Carmeni May 11, 2010
    jc8952 I did it last night but didnt took out the switches. I just clicked the switches many times. Anyway the TV worked for about 2 hrs and then went back to the flipping. I guess I have to take the switches out. Anyway thanks for the advice i know Im getting there. Will let you know.Thanks you saved me $150!!!!!!!
    Problem Solver:
  • 4 Answers
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons will leak when they get old causing them to activate on their own. your channel up or down button is stuck on. take off the back cover and you will see a small clip in circuit board behind the front panel. take out the board and remove the channel up or down switch and your set should work fine again. the remote will still work fine for changing the channels.
Posted on Oct 04, 2008
  • jc8952 Oct 17, 2008
    update: I found replacement tactile switches at Newark, part no. PTS645TL50. I replaced all six switches on the board and my TV works great now. I opened up one of the bad switches and noticed some deposits between the contacts from the copper plated actuator. This was probably causing a leakage of charge between the ground side and the high side which would activate the switch. If the set is plugged in then one side of the switch is always at high potential even when the TV is off.
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
35GT740 television
Have you tried to unplug the TV set for a half hour or so? If not see if that helps reset the set. If that does not work, make sure that none of the front panel channels buttons on the front of the TV set is not pushed in and stuck. Or if all this is checked and the TV set still scrolls, there is a problem in the remote sensor, or the front panel board will need to be replaced. Good Luck
Sep 10, 2007 | RCA 24V511T 24" TV
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
Reset set t.v. to channel 60 for DISH system without a remote for RCA tv
Use the TV's original remote to put it back on channel 60. The
Jun 21, 2017 | RCA Televison & Video
I need code to activate my tv and channels
You probably need to SCAN the channels.
Connect the signal source to the tv. Either cable or Antenna.
Enter the menu mode on the tv. You can do through the remote.
Scroll down to the signal source. Select the signal source you have connected to the back of set.
Scroll to SCAN in the menu.
SCAN in the channels.
Exit menu mode.
You can now watch available channels.
Feb 09, 2011 | Televison & Video
I only get 29 of my cable channels why is that?
Check ur package what u have order,turn off/on for reciever box to update info. for new signals.
Oct 07, 2009 | RCA F27442 27" TV
TV scrolls through the channels, over and over. Go
go to menu go to gemstar setup, set your zip code to 99999 and then exit. this solves 90%
Sep 05, 2009 | RCA F32650 32" TV
Channels keep scrolling
Check for a channel button on the front of the set.. one of them is sticking. Try spraying some WD40 around the front buttons and work each one to make sure none are sticking in..
Jul 31, 2008 | RCA F36650 36" TV
Channel selection woes continue!
Sorry but your going to need to get an original remote from a friend or relitive to program this set. They sell rca universal remotes for 10 to 15 bucks that will work for you too.
Sep 18, 2006 | RCA F27628 27" TV
RCA F32649 32" TV Logo
179 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
