Question about Zanussi Dishwashers
Zanussi dishwasher DE 2354\r\nWater not heating where do i locate the heater and what resistance should it be?
ghappliances
  • 126 Answers
SOURCE: WATER NOT HEATING IN MODEL
YOU NEED TO LOCATE THE THERMOSTAT AND CHECK IF ITS WORKING CORRECTLY IF THE READIND ON THE STAT IS FINE YOUR ELEMENT MIGHT BE FAULTH.BEST YOU GET A TECH TO ASSIST YOU AS ITS A TUFF JOB TO DO ALONE.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
  • 18 Answers
SOURCE: Water not heating up
There is a small round solinoid that might have blown its just under the element, you could try this, it cheaper option.
Posted on Aug 03, 2010
  • 18 Answers
SOURCE: where is the drain pump located on zanussi
The Drain pump can be got to by removing the circular filter at the bottom of your machine and all the screws that hold the plastics in including the round retaining plastic clip, only then will you see your drain pump prepellors, but if you want to remove the Drain Pump then this can be done from the rear of the machine you might have to remove the macine outside for this as you need to turn it on its side, from the back of the machine remove the two screws holding the big electronic motor this is plugged into electric sockets remove them also there is a rubber bung that holds this in place once unscrewed the motor needs a bit of a jig and it should slot out through the back of the machine. If you are thing of changing this it costs about £120 I got rid of the machine myself.
Posted on Aug 04, 2010
ginko
  • 19396 Answers
SOURCE: I have a zanussi ZSF2440s dishwasher, runs a
Hi.
Test and eventually replace either thermostat or heater. They can be tested reading impedance at their contacts. If there is no continuity (circuit open) then the part must replaced. Start from the thermostat that fails quite often.
Posted on Aug 22, 2010
SOURCE: where is the heater located in a zanussi zdt6255
Hi its in the rear bottom quite hard to get to, Is that the issue? you van test with ohm meter should be about 30ohms
Posted on Oct 01, 2010
DE 6850 not drying
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 16, 2010 | Zanussi 24 in. DE6850 Free-standing...
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi zsf4123 heating problem
Look at the wiring going to the ends of the heater to see if there is an inline thermal fuse that blows when there is trouble in the heater itself. It is about the size of a regular fuse, but may be contained in some kind of covering. It needs to be connected with crimp type connectors, because soldering can ruin the new fuse. Do you have a wiring diagram for this unit? It would help to locate the source of your problem.
Sep 07, 2009 | Zanussi 18 in. ZSF4123 Slim-Line...
Zanussi zsf6150 water not heating
Hi. i would test the element first. this will be the likely issue.
First, open the door
and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. Test the resistance of the heating element using a multimeter. Set the multimeter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading will be somewhere between infinity and zero. The exact reading differs by manufacturer and model. If the indicator does not move (infinite resistance) or moves to the other extreme of the scale (zero resistance) then the element is damaged and should be replaced.
Sep 02, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
My dishwasher works but is taking a long time to finish the cycle it is a zanussi DA 6373
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Nov 12, 2008 | Zanussi Dishwashers
WATER NOT HEATING IN MODEL DE 6850 Zanussi DISHWASHER
GOODLUCK.
MOHAMED
Sep 19, 2008 | Zanussi Dishwashers
Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Mar 12, 2007 | Zanussi 18 in. ZSF4123 Slim-Line...
No heat
You should check for 115/220v on heater tags, In case you don't have it, your problem is a malfunction thermostat that should be replaced. Good luck!
Dec 06, 2006 | Zanussi 24 in. ZSF6120 Free-standing...
Dishwashers Logo
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
