Equinox EX-300 Digital Scales OUR2 comes up on the screen when i turn it on
  • afumem1 Jan 07, 2009
    when i turn on the scale it says our2 what can i do to fix it?
    Problem Solver:
  • 9 Answers
Turn on your scales press and hold mode until cal flashes up the press and hold again until 100.0 flashes then put a 100 gram weight on it then will say pass if you havent got a 100 gram weight i used 14 2pence pieces and and a penny and thats it mine are working spot on now you can repeat the above when you get a 100 g weight but the coins are more or less **** on
Posted on Jan 04, 2009
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-P600 white LCD
had the same problem!
they changed the camera in the servicecentre, saing that it was manufacturer problem
Sep 23, 2007 | Casio Exilim Pro EX-P600 Digital Camera
Casio ex-m2
Does the Camera have internal memory? I think you need the card it to get any where Check out the manual
Dec 11, 2006 | Casio Exilim EX-M2 Digital Camera
Computers & Internet Logo
1,887 people viewed this question
David Payne
David Payne
