Question about Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
Think belt broke-how do you open it to get to the belt
What belt fits the hoover preferred?
Hello, this is Ava with Think Crucial.
In order to know the right belts to use for your Hoover cleaner, you would need to get either the model number of your unit or the part number of the belt. Hoover upright model number can be found either at the back or at the bottom of the unit while the part number can be found in the manual that came with your vacuum or you can do a quick search online. You may also contact Hoover (800) 944-9200 for further assistance.
You can purchase a wide variety of high quality Hoover replacement parts for your Hoover vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=hoover
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 10, 2014 | Vacuums
I have the eureka boss 4495 widetrack and the end piece of the beater bar broke off. I guess I put it back together wrong when I put a new belt on. Where can I get a replacement part and will it work do...
Call the Eureka people (1-800-282-2886) and describe to them what the beater bar thingy that you broke is. Ask them if you can order that unit--if you think you can install it. Otherwise, ask them where to the authorized repair person closest to you is located. Price the repair versus a new vacuum and good luck.
Apr 20, 2011 | Eureka 4495A Bagless Upright Vacuum
Where is the belt on a hoover agility?? My brushes stopped spinning and I think that the belt broke but I cannot find it
If you have the manual it should show the location of the screws or clips that hold the cover on for the belt.
Dec 03, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
My enviro vac is being stubborn
First , spin the brush roll by hand and see if it spins freely. Then remove it.
CLEAN OUT ANY HAIR OR THREAD UNDER THE CAPS Inspect the end caps , if one is melted you will need to replace the cap if available or the entire brush roll assembly.
The "metal piece" is the motor shaft. Clean any burned rubber of with fine wet dry sand paper, then install a fresh belt, using the brush for leverage to stretch the belt into place. Rotate the brush again to be sure it is not binding and that the belt is not pinched anywhere.
Buy 2 belts and keep your spare inside the hood of the vac.
Sep 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Beater bar does not turn but belt is not broke
i think there is 2 belts one for clutch ,one for brush
Jul 12, 2009 | Dyson DC14 All floors Bagless Upright...
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Belt broke
There should be an access panel on the top side of the cleaner. Pry this open with a screw driver and this should get you access to the area where the belt can be changed.
Apr 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue Logo
292 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
