Question about Dell Inspiron 6400 Notebook
My laptop is so recently hot . So, how do i make it cooler .
  • Khanh Nguyen
    Khanh Nguyen May 19, 2011
    thank you for your advice . but i don't want use third solution
  • 106 Answers
You can disassemble the laptop and clean cooling system with vacuum
Also you can buy cooling pad for laptop
The third solution is to switch laptop power theme - to power save, in that mode
it will generate less heat.
Posted on May 19, 2011
My Dell Latitude D610 keeps shutting down
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Jun 30, 2012 | Dell Latitude D610 Laptop Computer -...
Hot laptop
Buy a good laptop cooler, it will help quite a bit.
Jun 23, 2012 | Compaq Computers & Internet
U400 hot
That's a bit warm for idle. Here are some things to do and check:
1. Make sure all your internal fans are running.
2. Are you using it on a soft surface like a bed or pillow where the
exhaust vents are being partially covered up?
3. Go into Bios and tweek your fan speed settings. Raise the speed of
the fans if you need to. Some manufacturers set the speeds low to
keep noise down.
4. Get a laptop cooler (I Highly Recommend this).
If you do decide to get a laptop cooler you can always get a good deal at www.newegg.com. Newegg is one of the best and most popular computer/tech stores on the web.
Here is a link to their laptop coolers:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007639%20600028834&IsNodeId=1&bop=And&Order=RATING&PageSize=100
May 29, 2012 | Toshiba Satellite Pro U400-S1001V Notebook
My laptop compaq c795 is overheating and shutting down so plese give solution for reducing this heat
for about 20 dollars or so you can order a laptop cooler to keep it cooler the it is but laptops run a little hot because on its confined space
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007639%20600028834&IsNodeId=1&Tpk=laptop%20coolers
Sep 05, 2011 | Computers & Internet
Laptop is getting hot in upper left hand corner above the start button.
Laptops getting hot when use is common,it is just some models are too hot,you can buy a Netbook Cooler Pad to prolong the life and use of your DV9910US 17-Inch HP Laptop PC Notebook
Nov 22, 2010 | HP Pavilion DV9910US Notebook
My touch mouse keeps getting to hot and stops working.
sounds like you aren't using a cooler for the notebook. buy a laptop cooler with a fan before the cpu gets too hot and goes.laptops get very hot as you can see.
Oct 23, 2010 | Computers & Internet
Why my laptop is shutting down? it's getting very hot and his shutting down
Poor cooler under heavy cpu and or graphics job.
Try using laptop cooler.
The cooling system may have a probhlem. Try to go a service.
Aug 23, 2010 | Acer Aspire 5735 Notebook
Phillips Freevents 11NB5800
Hello sir, hi, try to check if the side exhaust fan is blowing out reasonable amount of hot air, if not you side exhaust fan is dirty, it may need cleaning, If the exhaust fan has reasonable amount of hot air blowing out, then you may need to buy laptop cooler, inquire about it at your laptop dealer.
Nov 07, 2009 | Computers & Internet
Tranmission heat...
I'm going to assume you have an automatic transmission? If so, look on the passengers side of the transmission...There should be two steel lines (like fuel lines) coming from the trans, going towards the front of the vehicle. follow either of them and it should lead you to the transmission cooler. (Ordinarily inside the drivers side tank of the radiator) It is possible that someone has disconnected it from the radiator and has used an aftermarket cooler mounted somewhere at the front (usually in front of the a/c condenser. I generally use these as an "add on" to the original system, not as a "stand alone) unless the unit is exceptionally large.
Jun 22, 2009 | 1999 Jeep Wrangler
Cooler too noisy
If the fan was working correctly, and is now making a noise it's probably a bearing/lubrication issue on the fan itself.
If the laptop is only 1 month old I would take it back.
Apr 02, 2009 | Sony Computers & Internet
Dell Inspiron 6400 Notebook Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
