Question about HP Scanjet 5590 Flatbed Scanner
How do you clean the underside of hp5590 glass?
  • 3 Answers
Detach the ADF assembly. Remove the 4 case screws from the scanner bottom. The case has a notch at the back that has to be unclipped to separate the top and bottom. Clean the glass underside repeatedly, I use methylated spirits on soft toilet roll. Check in the glare of the scanner light, and reassemble.
Posted on Jun 11, 2011
What are the approved cleaning fluids for use on the underside of the object glass?
  • Use any fluid approved for use on glasses or camera lenses. Glasses and photo lenses have coatings that should not be subjected to be acidic cleaners. Windex, for example should never be used on car window tint... who knew?!?
Feb 27, 2015 | Office Equipment & Supplies
Remove top glass from scanmaker 8700
Sir,
Please click on this lin http://www.artixscanm1.com/Cleaning_Instructions_Chassis_VI.pdf and download the manual for cleaning the glass for your scanner.
Go to page 2 and follow the instruction step by step.
Have a nice day.
Thanks
Oct 30, 2008 | Microtek ScanMaker 8700 Flatbed Scanner
How do I remove Scanner Glass to clean underside.
jast go and download service manual for 6110
http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
. Read it. Then try to open your printer's glass.
Thank you
Jun 01, 2013 | HP Officejet J6410 All-in-one InkJet...
I need to clean the underside of the glass but don't know how to take the glass bed off.
if you are not an expert, you need caution to remove the glass for cleaning.
CAREFULNESS IS THE CODE
Nov 29, 2009 | Microtek SCANMAKER 4850 Flatbed Scanner
Cleaning underside of glass on 610 scanner glass has mildew on underside
Ok. Found this question on-line as I also wanted to know the answer. Couldnt find an answer so I just decided to have a go myself. It was quite easy really. Lift the lid upwards and gently push it backwards from the hinged end and it will unclip. With the scanner facing away from you, undo the only 2 screws visible at the back. Then gently lift up and push forward towards the front. You can see thru the glass 3 plasic lugs holding the front down. With a little wiggle the cover with the glass attached will come away from the slotted holes where the plastic lugs go. Clean glass an carefully replace lid in the reverse order. Pete
Oct 23, 2009 | Epson Perfection 610 Flatbed Scanner
I need to clean the underside of the glass on my Canonscan Lide20
How on earth did the underside of the glass get dirty?
Ok, never mind that... in the end, it's NOT worth it. In the old days, you could have since scanners were as big as printers are today... but now they are definitely NOT designed for the consumer to service. The scanner is designed for accuracy, even if you were to get it all apart, the odds that you maintain the precision and integrity of the bulb, the track on which the bulb moves, etc, are very slim.
Suggestion... How is the printer you have holding up? If it's getting on in age, it may be a wise investment to purchase a dual scanner/printer (as long as you are spending the money).
Hope that helps :)
-- RT
Aug 29, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How to clean the underside of a microtek 9800xl
open it up...
you can try using a vacumm on the venting bars maybe it would help abit...
good luck
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
HP photosmart 2710 dirty glass
hi,
no way.... u cannot clean the underside of the glass... u can clean the glass using a lint free cloth....
thanks and regards
agnel
Dec 30, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP Scanjet 5590 Flatbed Scanner Logo
355 people viewed this question
Seeker5211
Seeker5211
