Question about Kitchen Ranges
When I engage my blade on my yardman riding lawnmower it smokes
  • 2,510 Answers
It sounds like the blades are not rotating freely and the belt is slipping in the pulley/s. Check the blades for freedom of movement and replace any bearings that appear tight. It could also be the belt tension that is too slack and the belt is slipping when the blades come up against a load. Check the belt tension. Your should be able to turn the belt through no more than about 90 deg with some resistance on a long belt run if the tension is correct. Remember to remove the spark plug lead before attempting any work on the blades etc, and please rate this response.
Posted on May 19, 2011
Yardman troubleshooting
More than likely the bearings on the mower deck that your lawnmower blades bolt to are seized or are close to it .Disconnect the negative battery cable from battery before you get anywhere near the underside where the blades do there business. Better yet, remove battery completely, and have it tested at AUTOZONE for free. While battery is out , check free spin of deck blades. Any resistance or grinding while blades are disengaged >debris , fence wire , rope tarp, etc.. or bearing failure. [DUE TO THE NATURE OF THIS PROBLEM AND THE POSSIBILITY OF SERIOUS INJURY, I WOULD STRONGLY RECOMMEND TAKING IT TO BE CHECKED AT INDY SHOP. ... ALTHOUGH COMMON SENSE WILL GO FAR IF YER MECHANICALLY INCLINED. .. YOU TUBES VIDS ARE A GOOD STARTING POINT. NOTE:BEARINGS CAN BE REPLACED,, WHEREAS A HAND OR A FOOT ...AINT AS EASY. Good luck
Mar 21, 2014 | Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
Yardman 42" . I just replaced the belt and now the
my moor goes a lot slower than useal pleas help me it is mtd 32.ins about 9 years old
Mar 12, 2011 | Mtd Drive Belt 42"
I have a yardman riding lawnmower and cant get the blades off what way do you turn it?
they are reverse threads., so you will turn them clock wise (I just pulled mine off 2 minutes ago. use a 15/16 socket with a cheater bar and they come right off. make sure you jam a peice of wood, I used a 4x4 to hold the blade
May 21, 2010 | LG enV VX9900 Cellular Phone
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
I cannot get any speed from my MTD/Yardman riding lawnmower. I have change the belts. It will engage But just will NOT go very fast. It is a sem-automatic.
Your yardman mower is a hydrostatic model which uses a small hydraulic pump to turn a hydraulic drive motor.Check there is sufficient oil in the transmission. Check the forward/reverse lever travel, and adjust as needed to increase the "throw" to move the swashplate in the hydraulic motor.
Jan 04, 2010 | Garden
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
