Hurricane h5200 modem/router
I tried portforwarding using portforward.com guide. but the problem is my local area network cannot see my servers using fqdn. other pc (internet, public and other computers not connected to my network that doesnt pass the modem/router) can see my servers.
if i go to my fqdn on my local area network i see the router config page. also other ports that are being forwarded are not working in local area
is there a tweak or config on the router/modem h5200?
i need help anyone?
  • Nick Sharp May 11, 2010
    jmazaredo
    Could you please provide some more info, specifically how your network is set up and what servers you have
    Regards
    Nick
    Genius:
  • 1,139 Answers
Hello jmazaredo,
Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
In other words edit your hosts tables (hosts file) with the entry (Example 1):
IPADDRESS FQDN ALIAS
192.168.10.2 somesystem.myhome.com. system
192.168.10.5 somesystem2.myhome.com. system2
This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
Once this is done if it works then try this setup:
1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
I hope this helps.
Thank you,
Shuttle83
Posted on Oct 26, 2008
HOW DO i BLOCK PORT 80
Port 80 is the web port. Whenever you look at a web page you are going to port 80 on the server. If you block port 80 then you won't see web pages. I am assuming it's outgoing traffic to web servers you wish to block. A standard router will have incoming port 80 blocked by default. You would OPEN port 80 if you had a web server at home.
Feb 22, 2015 | Apache Micro Peripherals Computers &...
Trying to open port 3389 in my firewall. Set for UDP and TCP but the tester program still says that they are closed. I have disabled windows firewall. Still no luck.
Make sure you are doing this for the right ip address. The ip address should be your local computer's ip address and will probably look like 192.168.1.x . To get to this go into your network control panel and click on your connection and view the details to get this information. Remember that every time your router resets this ip could change. I would suggest setting a static ip in either the router or on your computer in question. To set up a static IP for windows xp: http://portforward.com/networking/static-xp.htm. For windows Vista:http://portforward.com/networking/static-vista.htm. For windows 7: http://portforward.com/networking/static-win7.htm.
May 13, 2011 | Belkin F5D8236-4 Router
Router portforwarding
Use the below website to configure your port forwarding
Choose your modem type and application that u want to do port forwarding..
Aug 18, 2009 | Cisco CAB-OCTAL-MODEM (CABOCTALMODEMBXF)
Motorola Router SBG900i blocks download from particular server
The best page for portforwarding can be found here.
It mainly depends on the software and the ports used, so it might differ from application to application.
Portforwarding.com has excellent user guides.
Jan 07, 2009 | Arris SURFboard 2.4GHz Wireless Cable...
Port forwarding
http://portforward.com/guides.htm
http://portforward.com/english/routers/port_forwarding/Dlink/DI-624/Utorrent.htm
Dec 16, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Portforwarding using a Motorola SBG900 modem
Go to portforward.com,find your router in the device list and follow the instructions. Works great for me.
Oct 12, 2008 | Arris SURFboard SBG900 Wireless Router...
Port forwarding web server
Use the Public IP of the router or go to http://whatismyip.com then use that IP address on your browser
i.e http://24.x.x.x:80
Or go to http://portforward.com and click on guides and then port forwarding. Then choose the brand and model of your router and then follow the steps on that page.
Hope this helps, gambatte!!
Sep 22, 2008 | Actiontec GT704WG Wireless Router...
Port forwading
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
My RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Aug 23, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Aug 05, 2007 | Linksys WRT300N Wireless Router
Computers & Internet Logo
299 people viewed this question
David Payne
David Payne
