Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer will not heat up. model gleq2152es1
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';
Posted on Jun 12, 2011
How do I do a hard reset of frigidaire dryer GLEQ2152ES1
Unplug it overnight. That will definitely reset it. Did you remove the cover where e the lint filter goes in. It is usually held in by two screws from the inside. There should be two wires leading to two metal strip on that cover. Make sure they are clean. You can also reach down into the lint trap to remove any more lint.
Aug 19, 2016 | Frigidaire Dryers
Frigidaire front load dryer not drying all panel lights flashing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Frigidaire Dryers
I have a frigidaire gleq2152es1 that keeps blowing heating elements, what is the cause?
Are you re-stringing the element? if so you need to make sure you have no gaps in the element.
Jan 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
I have a Frigidaire Gallery Dryer # GLEQ2152ES1. Bought it used. No probles for several months. Moved to a different location. Dryer works but not heat and shuts off frequently. I replaced the control...
Hello - Since you have previously replaced the control board and confirmed that the high temp sensor is working fine, unit may possibly have a defective sensor, heating element, power supply or a communication problem with the control board. I suggest contacting a professional to move forward accurately. The technician usually warranties their labor just in case something else may turn out to be the root cause of your initial problem.
Oct 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Electric dryer model#gleq2152es1 we turn the dryer on, it will run for 15 minutes or so, not heating...then all the lights on the side will flash and it stops. I have seen many issues exactly like mine...
You may have a thermal switch defective. This is a switch that reacts when temperature is exceeded. Before you undertake repair do the following steps:This problem may be caused by the dryer air filter that filters the lint excaping the dryer .(1) Remove the dryer air filter, clean the lint from the screen , wash the screen in hot water using dish soap, ( this will remove the Fabric Softner also called Fleecy sheet which deposits an invisible film on the mesh screen that can not be detected so easily) . Once you have done a good cleanig of the air filter screen, reinstall it and operate the dryer....(2).if this has not cured your problem then open the top cover of the dryer (using a kitchen knife to trip the cover clips located at the front ) and you will find the thermal swich located near the top of the door edge. Check it with a meter to check continuity (to check it is closed), if it is opened , replace the thermal switch.
Good luck and good repairs.
Aug 21, 2017 | Frigidaire GLEQ2152ES Electric Dryer
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
140 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
