Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Loss of suction - not picking up right when hoovering carpet. It looks like the brush bar does not stay flat to carpet.
faggly
  • 74 Answers
SOURCE: Suction loss?
hi samdan... have you checked all the hose attachment vents .. ie Under the vacuum as well... How long is it since you replaced the filters?
Try giving the Yellow cone inside a blow out. these tend to become clogged from time to time!
Regards Faggly
Posted on Mar 21, 2008
  • 6 Answers
SOURCE: dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
Posted on Mar 03, 2009
SOURCE: No Problems with suction on hoses, however brush area it seems to lose powe, and has little suction r
We had a similar problem with ours and had to finally take it to the repair shop. They informed us that we needed to replace our clutch and that you needed to do that every 2-3 years. It cost less than $100 and has been well worth it.
Posted on Jun 24, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
VacuumRepair
  • 438 Answers
SOURCE: Lost suction. When up right there is suction but
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free, rather then just the premium ones that users pay to have answered. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
Posted on May 07, 2010
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
How do I adjust the height of the brushes and suction
look for a blockage -something may have dislodged the lever mechanism, or be stuck preventing the roller or position leaver from moving.
Sep 26, 2014 | VAX Appliances Vax X5 Bagless Upright...
Hoover u6485-900 Brush Bar won't turn.
Hello. Make sure that the brush bar is clean and that there is no hair or strings tied up.
Apr 18, 2014 | Hoover U6485900 Bagged Upright Vacuum
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
120 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
