Question about Casio FX9750GII Graphic Calculator
How do you turn frequency on when in the stats table mode on a casio fx-9750gii?
  • Casio Master
  • 7,993 Answers
There is no such thing as turning the frequency on on the Casio calculators. Just enter your data in lists. Choose one List where you put the frequency information. When you want to GRAPH or perform CALCulations you have a TAB labeled SET corresponding to key F6:SET. When you press F6, a new screen open where you assign the list to the variables.
Here are a few screen captures to help you.
Press F2:CALC (or F1 Graph). The Tab SET appears at the bottom of screen
Press F6:SET
Higlight the line 1-Var Freq (or 2-Var Freq). The bottom of screen shows F1:1 and F2:LIST. If frequencies are not equal to 1, press F2:LIST to assign the frequency list. I enhow do you turn frequency - k24674_71.jpg>
k24674_71.jpgk2467how do you turn frequency - k24674_73.jpgss=
Press EXE to perform stats.
See that n=19.
Posted on May 25, 2011
Fx- 9750gii ... I deleted the table on my table
If the table contains experimental (statistical) data that you gathered and put in a table on the calculator, then I am sorry to say that if table is deleted there is no way to get the data back. You will have to renter it.
However if it is a table connected to a function you graphed then the table can be regenerated: Type in the function anew, press the table function key, then graph it.
Oct 18, 2013 | Casio FX9750GII Graphic Calculator
My Casio fx-9750GII wont dispay a table
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)
I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Nov 05, 2012 | Casio Calculator Graphing FX 9750GII...
How do you find the standard deviation using the list function when you place values in two lists? (Casio fx-9750GII)
It depends what the two list mean.
If you are doing 1-var statistics you may want to enter the frequency of a data element (if some are repeated) in the list L2.
In that case when you run the CALC 1-Var , you first press the F6 key to set the lists Data List1, and Frequency List 2.
Once you set the lists, press the F1 key to select 1-var. The calculator will give all the statistics of the distribution.
If you are doing 2-var stats SET the lists and press F2 2-var. The calculator will give you the x-statistics, followed by the y-statistics.
Sep 17, 2011 | Casio FX9750GII Graphic Calculator
How do i use the equal sign when doin an equation?
With this calculator, you cannot do (solve?) equations. It has a general computational mode (COMP), a table mode (TABLE) and a statistical mode (STAT). You can find these by pressing the MODE key.
Jul 16, 2011 | Casio fx-300ES Calculator
How do you set the intervals for a histogram on the Casio fx-9750gii?
  1. Arrange you data in ascending order
  2. Determine the frequency of each datum (for un-grouped data)
  3. Turn Calculator ON
  4. Press the MENU key
  5. Highlight STAT icon and press EXE
  6. Enter the data item in list1 and frequency in list2
  7. When finished entering data press F1:Graph
  8. Select Graph1, Graph2 or Graph3 or SET to fine tune
  9. Select the Type of graph (Histogram)
  10. Select the lowest boundary of the first class (to align)
  11. Set the class width
  12. Press EXE to draw.
Here aree some screen captures to help you along.
They are in chronological sequence. If not just rearrange the sequence.
Apr 26, 2011 | Casio FX9750GII Graphic Calculator
I have a Casio fx-9750GII, how do i switch my radians to degress?
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Jan 19, 2011 | Casio FX-9750GPlus Calculator
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
How do I calculate normal distribution using a fx-9750gII?
I don't know about fx-9750gII, but for fx-991MS
Change the mode to REG
Then
Shift->3(DISTR)->1(P())->give your Z value
Jan 07, 2010 | Casio Office Equipment & Supplies
Trying to find standard deviation on the calculator
I took statistics last semester and I don't really remember how, but after you enter your data, you press SHIFT, then STAT (on the 1 key), then I think it's under 5 (VAR), and maybe Xon-1? Eh, funny how long you remember this stuff for....
Apr 15, 2009 | Casio FX-115ES Scientific Calculator
Casio FX9750GII Graphic Calculator Logo
1,283 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
