Question about Sony Handycam DCR-TRV250 Digital Camcorder
The tape is not feeding. It says eject and the camcorder will not work.
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on May 25, 2011
My Canon Elura 80, digital camcorder, has been acting up for the past year. First, it went through a period where it refused to eject the tape. In this, I mean I could open the side panel, but it would...
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 06, 2010 | Canon Elura 80 Mini DV Digital Camcorder
Sony ccd-trv43 showing c:32:00?
Error Code = C:32:00 - Tape will not eject... I found that the Camcorder ate the tape and the tape was rapped all up inside the Camcorder, preventing the tape from ejecting. I took the Camcorder entirely apart and removed the tape manually and re-assembled the Camcorder. When finished there were no extra parts or screws and my Camcorder works perfectly once again. However, I DO NOT RECOMMEND this procedure if you are not confidant that you can disassemble and re-assemble your Camcorder.
Dec 05, 2009 | Sony Handycam CCD-TR416 Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape will not eject
I had the same problem and I switched to smaller tapes. I had been using the 120 minute tapes. It seemed like the tape would lock up after a short while with the larger tapes.
Apr 05, 2009 | Sony Handycam CCD-TRV21 Camcorder
Mini dv
mam try to check the tape if its correctly inserted to the camcorder. it must the tape itself or the tape compartment has the problem. insert the tape and see if its feed to the tape head and be sure that it will close with no problems. if the problem still occuring or persisting then try another dv tape and see if you got the same problem. otherwise go to the nearest repair shop to be able to fix with the use of their tools. hope that helps you ma'm!
thank you for using fixya
CHARCOIS
Dec 10, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
Tape door will not open
the tape eject door will not open there is currently a tape in the camcorder (panasonic pv-l559)
Jan 09, 2007 | Panasonic PV-L559 Camcorder
Sony Handycam DCR-TRV250 Digital Camcorder Logo
27 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
