Question about Poulan 14" Chainsaw
I have a Poulan 14"
  • 843 Answers
Inside the fuel tank, there is a small flexible fuel line with a float (or sinker) attached. The float (or sinker) is supposed to keep the end of the fuel line submerged in the fuel. The float (or sinker) may be detached, or stuck, or it may be saturated and won't float (if it's the floating kind).
Good luck, Al K
Posted on May 20, 2011
1950 poulan
Open fuel tank, pour out fuel on clean flat area (away from any flames or spark sources) then check the 2 plastic hoses inside. One should have a fuel filter on it's end. The plastic these lines are made seams to disintegrate so, filter may not be attached and lines may be broken off. Replace them.
Mar 05, 2013 | Poulan 14" Chainsaw
How do i tell what "type" of Poulan Model 1950 saw I have
The type no. should be on the ser no. plate 1-8 there are small changes between the type no.s but they are all model 1950, is this the machine that you inquired about the sprocket? as that was not the model quoted in you first question!!!!
Jan 13, 2013 | Poulan 14" Chainsaw
Runs for a few seconds & dies
Fuel starvation, start by replacing the fuel filter in the tank on the end of the fuel hose, check the hose for cracks or slits.
Aug 21, 2011 | Poulan 14" Chainsaw
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
Runs about 20 sec. at a time, quits starts back up run again then quits...
had same problem, mine had water in the feul tank, drained tank and cleaned carburator , works fine now
Sep 09, 2010 | Poulan 14" Chainsaw
Poulan 2150 Chainsaw
You have it plumbed incorrectly!
EXACTLY like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Suction side to carb. Pressure side to tank.
It does NOT squirt fuel into carb throat. It bleeds air from fuel system. All 2-cycle engines work like this.
Lou
Mar 10, 2010 | Poulan Garden
My saw will start but dies immediatly
Spark plug gap The right spark plug and the right gap is critcal to good running on a 2 cycle motor(you DO have gas in it right?)
Aug 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Piston ring install up or down Poulan 2150 16"
the groves go into the pins.v is up to fit into those pins.the pins go to the intake side of piston
Jan 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 14" Chainsaw Logo
126 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
