I think i inadvertently uninstalled my speakers on my E197FP Dell monitor. how do i reinstall so i can get sound back? I don't seem to have a CD specifically for the monitor, only for my computer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 247 Answers
Please restore the system setting
Posted on May 19, 2011
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
I have a dell optiplex gx270 and I installed a sound card. It sounded horrible so I uninstalled and removed the sound card. Now, the audio on my computer sound muffled, echoed, like in a barrel. When I...
Your board has ADI(Soundmax) sound. There is no support for Soundmax anymore. You may want to check into why your sound card gives you rotten sound and/or check into another brand/type of sound card. What kind of card do you have and did you get the most recent drivers for it?
Dave
Jul 28, 2011 | Intel 865G Motherboard
My Dell LCD monitor has a blue tint. I've tried another monitor and cable with the same result
try to reinstall video driver, if does'nt work. you need to replace your video card. if it is built-in. replace your board
Feb 19, 2011 | Dell E197FP
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
The monitor screen has a yellow tone to it.
try the new monitor with a different pc, if it works fine, your PC has a videocard problem..
May 08, 2010 | Dell E197FP LCD Monitor
Dell E197FP - Screen turns off and on constantly
Check the video connector to make sure it is clean and tight. Look closely for broken or bent pins by GENTLY rubbing your finger across the pins.
Otherwise, it sounds like the monitor screen is failing or has faulty wiring or components inside.
Sep 03, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
