Question about Jabra BT250 Consumer Headset
My jabra bt250 headset wont turn on
I hold down the button nothing happens i have been doing all sorts with this button but nothing happens i but it on charge i get one flash but then if i change the socket of the charger with the headset on charge i get flashes thats all that happens can you please help?
  • Anonymous Dec 09, 2008
    how to reset the device
  • 4 Answers
Check my post on solution 4 on this link, my headset still working 1 month after i boosted it.
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Dec 18, 2008
  • dididocky Dec 18, 2008
    the problem with jabra or so it seems is when the unit is left for long periods of time the battery becomes totally flat i.e 0.0v but the circuit in the units looks like it need to see just a small amount of voltage to enable the micro chip to work and start the charging process. so your headset and battery are probably ok, just need to get a small amount of boost in the battery to "jumpstart it" like jumpstarting a car with a flat battery, the electronics cannot function with a low voltage. i hope that makes sense to people other than me. and check my previous post and link to a small guide which may help you repair it yourselves
    good luck
    Problem Solver:
  • 4 Answers
Make sure it's charged. Hold button to turn on until you hear a rising tone. A blue light flash every few seconds says that it is on. If this fails, I suspect your battery will no longer hold a charge.
Posted on Aug 31, 2008
2 Suggested Answers
  • 16 Answers
SOURCE: I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
Posted on Jan 07, 2010
Want to reset my jabra to use with my new i phone
Turn off the headset.
Hold the power/call button to make it discoverable.
Add it from your iphone using password 0000 or 1234
Jun 13, 2011 | Jabra BT250 Consumer Headset
Wont turn on
If it is fully charged, press and hold the top button until the blue led light comes on. To get it into pairing mode you need to switch it off, then switch it back on but hold the top button down for 8 seconds until the blue light comes on and stays on
Aug 27, 2010 | Jabra BT250 Consumer Headset
I have lost instructions from my Jabra BT250 and can't remember how to pair? my new phone is a htc
switch off jabra. Hold down on/off button for sabout 10 secs until blue light is continuously on. Then pair from the phone. Pin 0000
Jul 05, 2009 | Jabra BT250 Consumer Headset
How do you turn off vibration on jabra bt250
Check the Jabra support site for the manual.
It is a simple hold the volumne up when switching on and then if you want to renable it hold it down when switching on.
[or the other way !!] but that is all.
Dec 17, 2008 | Jabra BT250 Consumer Headset
BT250v vibrating after picking up the call
Check Jabra website for manual.
It is a simple hold volumne button up or down when switching on or off to disable /enable it
Apr 21, 2008 | Jabra BT250 Consumer Headset
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
Headset won't go into pairing mode
Power off the device and do not turn it on before holding down the botton to put in Par mode. Once it is off, then hold down the button usually takes about 5 to 10 seconds to turn solid and enter par mode. If this does not happen you may have a defective unit and may need to return for a new one.
Dec 20, 2007 | Jabra BT250 Consumer Headset
Jabra BT205 connection
you need to hold the power putton some seconds longer when you turn it on, until it starts blinking in an other pattern...
Sep 21, 2007 | Jabra BT250 Consumer Headset
Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
May 26, 2007 | Jabra BT250 Consumer Headset
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Jabra BT250 Consumer Headset Logo
666 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
