Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
We've connected this monitor to our Acer tower but we get nothing on screen. Can you tell me what the buttons are on the monitor and if that might be the problem.
  • 11,361 Answers
You can download user manual for your monitor here:
http://tom.viewsonic.com/pdf/userguides/va712b-2_ug_eng.pdf
You should try this monitor with another PC to find out if it is your PC problem or your monitor problem.
Posted on May 20, 2011
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Can i upgrade my old monitor to a new acer 19" Acer Monitor
Hi Ricky,
In most situations you won't need any special connections, as most LCD screens have the same VGA interface sockets and cables as your older screen.
Let me know if I can be of any further assistance.
Best wishes,
Graemevm
Jan 24, 2012 | Acer Aspire T120 PC Desktop
Hi, I have a Princeton LCD17D flat screen monitor and the screen keeps going black after 20 seconds or so. I power up my PC and it turns on then black. If I turn it off and on again the same thing occurs....
It's getting power, it's just not getting signal from the data cable. The cord that connects to the monitor, (not the power) is typically the reason it is going into standby mode. This can also happen if your graphics card driver is missing on your operating system, but you said you tried the monitor on another machine, so I narrowing it down to most likely be the data cable. Try another cable.
Jan 09, 2012 | Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I need the acer monitor drivers for windows seven al1706a
    As I'm sure you're aware Acer doesn't offer a specific driver for this monitor. However, any driver for your video card that offers a 1280 x 1024 screen resolution should work. What screen resolutions does your current driver offer? If you want to update your video driver download a newer video driver from the firm that made your video chip. You can find out what you've got by launching Device Manager. (click on the start button and type device manager into the search box) If you decide to update your video driver click on Display adapters entry in Device Manager and right click on the video chip entry that will emerge as a subgroup. Select update driver software from the choices displayed when you right click. Then tell it where the driver you've downloaded is located.
    Aug 09, 2011 | Acer AL1706AB LCD Monitor
    I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
    I would try this monitor with another PC first to verify that it is not PC problem.
    Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
    See examples of failed ACER due to bad caps here:
    http://s807.photobucket.com/albums/yy352/budm/ACER/
    Basic LCD monitor and TV troubleshooting guide:
    http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://www.fixya.com/support/r7406380-tv_training_manuals
    Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
    Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
    Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
    Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
    Jun 24, 2011 | Acer X203H Monitor
    My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
    I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
    Please don't suggest going to control panel, as I can't get that far.
    PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
    Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
    Monitor Acer Problem
    I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
    Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
    Open Questions:
    ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
    Top ViewSonic Computers & Internet Experts
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
