Question about Garden
I have a gilson 51095-44845 compact tiller. The brass drive gear in that mates with worm shaft is shot, is there anywhere i could get one?
  • tim haessler Jun 16, 2013
    i have the same tiller and cant find a ign coil :(
  • alex bitz
    alex bitz Sep 15, 2014
    i also need the same brass gear. Did you locate one???
  • 69 Answers
SOURCE: looking for belt diagram for gilson brothers
Gilson stuff was eventually bought out by Toro. You may want to try the Toro website for some asnswers.
Posted on May 06, 2009
  • 376 Answers
SOURCE: I'm trying to remove the old steering shaft that
It may seem like it won't go, but it will angle out past the engine. Pull the shaft up a bit and angle it out the side between the engine and dash.
Posted on Jun 16, 2009
bohardin
  • 13 Answers
SOURCE: I have a Gilson Bros. Rear Tine Tiller. I need
check and if the end off axle has a swelled place use a file or sand paper to smooth it out.try some penetrating oil that will help
Posted on Jul 12, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
  • 1114 Answers
SOURCE: broken belt
The web site below sells Gilson belts - you need the part number. If you do not have the part number, maybe if you contact them, they can match the belt to your tiller number.
http://www.psep.biz/store/gilson_tiller_belts.htm
Also, another web store, Jacks small Engines (jackssmallengines.com) states that they carry parts for Gilson, but I did not find Gilson in their directory. You may have to contact them.
One of the web sites mentioned that at some point Gilson was bought by Lawn Boy. If you go to a local Lawn Boy dealer, they may be able to match up a belt.
I have a 1978 WheelHorse tractor. The drive belt for the mowing deck broke. I went to Home Depot, spend a good 1/2 hour measuring belts, and found one that works perfectly. If you go to your local outdoor equipment shop, especially one that sells, repairs tillers, they may be able to match up a belt for you. A belt is a belt is a belt. If you go to a "good old fashioned shop" that will spend the time, they can measure the old belt and hopefully come up with a match.
Good Luck!
Posted on Jul 29, 2009
Replacement Idler pulley for Gilson Compact Tiller Model 51095
Is this a press on pully or does it have a thru bolt? if press on is it a splt pully .If it is a split pully it should have 2 threaded holes in the hub where you screw in the back out bolts. These kinda act like a built in gear puller to facliitate removal.Its a easy pleasy 5 minute job.
Jul 15, 2014 | Garden
Replace the roller bearing on mantisworm shaft
I posted this same procedure in a reply to this post:
http://www.fixya.com/support/t2127031-tine_shaft_removal_mantis_2_cycle_tiller
Follow the procedure for removing the worm gear shaft by removing the retaining ring at the bottom of the housing and extracting the worm shaft and other associated parts, Adding heat to the bottom of the housing to expand the hole will help the removal of the #458 roller bearing - with the housing in a vise, tap on the top of the worm shaft through the top hole of the housing with a punch or rod smaller than 1/2" in diameter. Then remove all grease from the housing - to eliminate the remaining roller bearing pieces that may reside in that grease. After total teardown and cleaning place the worm gear housing in a vise apply heat with a propane torch to the outside of the worm gear housing in the vicinity of the beaing location. Applying heat to this area will make the housing expand and make it easier to remove the remnants of the old bearing. With the housing still hot, take a punch or piece of 1/4" steel rod and insert it from the top hole, where the drive shaft goes in, there is a large ridge in the cast housing that the bearing mates against and immediately past that the bearing body will protrude just a little more into the cavity, with the rod against the bearing body gently and rapidly tap on the rod. You can look into the other side through the housing cover opening to be sure you are on the bearing and not the cast metal ridge. I just replaced that bearing this morning, be careful putting the new one in as well, they can be damaged very easily if you don't apply even pressure.
May 17, 2014 | Mantis 2-Cycle Tiller
Tru-test tiller parts
Is there a bushing on the front of the drive on a tru-test tiller
Apr 11, 2012 | Garden
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Just need to see the order in which the parts go back on the drive assembly for a Ward/Gilson 1575 front tine tiller
which drive assembly do you need info on,the belt drive or the gear box/case ***'y,I have a manual and can send a pic if needed,plus I have microfiche also on most of the Gilson jed1950@earthlink.net
Jul 16, 2009 | Garden
We need to replace the brass wormgear in our older eaton viking rotortiller. Know where we can find this part?
Hi the old viking tillers used the gilson gearbox , and the gear
is avialiable from toro It is expensive cost about 135.00 dollars
May 03, 2009 | Garden
Tine shaft removal for mantis 2 cycle tiller
Put the tiller in a vise clamping on the bottom of worm gear housing. Remove worm gear housing cover. Clamp the worm gear at the top with a vise grip (I think Kuya Jon is correct in that you could skip this step because the transmission won't move when unscrewing, but I did it anyway just in case). Put a pipe wrench on the left tine shaft and unscrew it like it was a normal bolt. It's in there tight and it will take some force. When I unscrewed mine, the left bearing seal retainer, left bearing seal, and left bearing all came out with it. I just needed to replace the seals. I went to the right side, and with a screw driver carefully pried out the retainer. Then it's easy to just pull out the right seal with your finger. Put a new right seal in and insert the right retainer. Make sure the retainer is facing the correct way. I used a block of wood to tap mine in once I had it positioned because I was afraid to hit the retainer with a hammer. Now I put the tine shaft back in while holding the worm gear with the vise grip. Screw the shaft as far as it will go by hand and then go the rest of the way with a pipe wrench. Now came the tricky part. The right bearing did not slide right in. There was some resistance. I had to use a 1/2" threaded pvc pipe (not sure it needs to be threaded but that's what worked for me) longer than the tine shaft that was sticking out. I slip the pipe over the shaft against the bearing and tapped with a hammer. This drove the bearing in all the way. It needs to go in far enough to leave room for the seal and retainer. The plastic pvc allowed for this. Now put the right seal in. If the outer edge of the seal is only flush with the housing you did not tap the bearing in far enough. I made this mistake on my first try and tried to force the retainer in. Take it from me. It won't work. You will end up ordering another retainer to replace the one you mangled. Once in properly I slid the retainer over the shaft and then put a washer over that to tap against. The block of wood doesn't work on this side because the shaft is in the way. I used my pvc pipe again to tap against the washer and, wala, it worked like a charm. I hope this helps someone. All the other posts really helped me. Thanks!
May 01, 2009 | Mantis 2-Cycle Tiller
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
Garden Logo
607 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
