Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Water is leaking from the inside of the washer of the cold water intake. It seems to escape on top and right under the inside sensor that is on top of the one piece Y sectioned intake. Model: Bosch Nexxt 100? Thanks, Jan
  • precisionarm May 27, 2011
    Part (coldwater intake boss) came in yesterday @ $49.00 (incl. shipping) and repair proved to be quite simple and straight forward. I guess I just saved myself a coule of hundred dollars there?
    Cheers,
    JK
Don't have a solution but I have the same problem
Posted on May 25, 2011
  • precisionarm May 26, 2011
    Thanks,
    I guess not really helpfull, other then the knowledge that I'm not the only one with this particular problem? I've just ordered a new complete coldwater- valve intake last week, wich I will install myself. The service man was going to charge me $180.00 for just coming out this way, plus whatever hours & parts the repair would take! Any suggestions on how to take it apart would be helpfull?
    Cheers,
    JK
Washer is leaking water from the bottom right side
check your hot cold connections going into the washer might have to take top part off to seee inside might just be a rubber seal
Mar 17, 2013 | Maytag Washing Machines
What is LF message
LF means a long fill was detected. This means that the washer sensor did not sense enough water coming into the unit in the first 8 minutes after starting the wash cycle.
There are several things that you can check. First, make sure that the incoming water pressure is good. You can try replacing the intake hoses and checking the filters on both sides (inside the washer and at the shut-off valves). (When you take the hoses off the shut-off valves, put a bucket under the outlets and check the flow rate.) Some intake hoses will seal themselves if they detect a leak. This will significantly reduce the water flow. If the filters are clogged, you get a similar restricted flow.
Next, check that the end of the drain hose is not positioned below the fill level of the washer. This will cause the water to be suctioned out of the tub as fast as it fills.
If the water is flowing well, the intake valves or the water pressure sensor (which detects the change in the weight of the tub) could be bad or have a wiring harness problem.
I hope this helps.
Aug 25, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Replacement of coolant temperature sensor location of coolant temperature sensor on 2.5 gt
located under intake in water crossover pipe,you can access the sensor by removing intake chamber box,then pcv hose connected to the block,the connector is orangeish 2pin,use a 19mmdeep socket on a 3/8 ratchet to get it loose,make sure engine is cool,also make sure there is a new brass washer with your new sensor,sometimes the old washer comes off when removing the sensor,sometimes it sticks to the pipe,some coolant will escape so make sure to top it off
Jun 26, 2009 | 1996 Subaru Legacy
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to leak fresh water into washer tub
This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak into washer
The solenoid for the water intake is faulty. It may just have some crud stuck in it. You have two, one for hot and one for cold connected directly to the hoses on the back. You can shut off the cold water supply and see if it still leaks - if it does the hot water solenoid is faulty - if the leak stops then the cold water solenoid is bad.
Nov 22, 2008 | GE WBSR3140DW Top Load Washer
No cold water regardless of setting
2 things it can be if your water pipe were you connect the hose too under the sink has a plastic turn handle to switch the water back on then it is most likely that it has sheard inside it undue the screw that holds it on pull the plastic cover off and with pliers turn until you hear the wate rcome through if not then it will be the solenoid inside your washer that has become faulty were the pipe connects to m8
Sep 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
106 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
