Question about Thermos Grill2Go Fire+Ice
Shelf for over fire of portable gas grill
Portable cast iron grill that can be carried to beach. need metal pc.for over open fire pit. 101/2 by141/2 grill is 17 "
by11" grill is 10 year old. still great too.
  • 10,865 Answers
Http://www.charbroil.com/Consumer/ConsumerCreateCase.aspx
go to this link and fill lin the boxes, then tell the charbroil customer service dept. exactly what u need.
Posted on May 15, 2009
  • Joe Hogan May 15, 2009
    Enjoy your grill.
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
I'm trying to locate a replacement coal grate (perferably in stainless steel) . Can you supply one? Thanks tlynch@inficon.com
Sorry, we don't sell anything on FixYa. However, if you get the dimensions of the grate you needand search around on Google for some the Grill Parts & Accessories sites and you're more than likely to find what you need. I will caution you, Stainless Steel Grates are expensive. Plus, they do not do well with charcoal. The charcoal gets so hot against, that it will pop and pit. It's not like doing it on a gas grill, where the heat is moist and the stainless retains it's integrity. Unlike coal or charcoal, which is an extremely dry heat. You may be better off with Cast Iron. Once it's seasoned, it should do better than Stainless Steel.
Hope this helped you. Please let me know. Thanks/
Jun 21, 2011 | Patio Classic 2000 Series Grill
How does the Brinkmann grill model-810-2545-w rank I want to get an idea before I buy it & is it a good grill--Ken
The best answers you can get from those ones who already purchase it. Click here Amazon com brinkmann grill (seller with most reviews) and read the reviews. I hope this was helpful. cheers
May 13, 2011 | Brinkmann Smoke 'n Pit Professional...
I HAVE JUST PURCHASED AN IRON HEARTH OUTDOOR FIREPLACE GRILL MODEL 30072. WHEN WE STARTED TO BURN FIRWOOD THE BOWL CRACKED, ABOUT A 6 INCH HAIRLINE CRACK. wE DO NOT BELIEVE WE OVERTIGHTENED THE BOLTS AS...
If the outdoor fireplace was put together correctly, it shouldn't have cracked under normal use. I would contact the manufacturer about a refund/replacement. Outdoor fireplaces in general are designed to stand up to very high heats and outdoor conditions. I do not believe that you can replace just the bowl. You might be able to seal it with a high heat resistant sealant/bond, but I would try to get a refund. It sounds like your grill might have been defective.
Jul 19, 2010 | Kay Iron Hearth Portable Fire Pit Grill
How to clean cast iron grill
do not use any chemicals!!! just whipe it off with old newspapers or kitchen absorbent paper and that is all.
leftover fat will preserve metal from rusting, next time when you lit it, when it is hot, just splash bit of beer (yes, i do not joke!) on the surface, allow it to run off and then whipe rest off. alcohol and acid in beer will lift old fat and refresh the surface, adding as well flavour to new bake.
spray your fat and cook as usual.
that is all clening which is required for cast iron plates.
if you find my advice helpful, plese do not hesitate to left your opinion and leave 4 (or less...) votes for me, thanx!
Jul 01, 2010 | Weber Baby Q Grill
Welding bearing girdle for Hobart A200?
yes the cast can be welded(brazed). if you are able to weld this yourself, just remember before you can weld it, you have to heat it till it is cherry red then you can weld the piece. if your not qualified to weld it you can usually find a portable welding company to do this for you. hope this helps you please rate the solution...thanks
Sep 18, 2008 | Hobart A200 Stand Mixer
Burner replacement
If you ermove the control panel on the fom you should be able to slide the gas manifold back a little thus putting the nozzle into the burners.
The manifold has a couple of screws at the sides
Jul 29, 2008 | Viking VGBQ410-3RT Grill
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Thermos Grill2Go Fire+Ice Logo
118 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
