Question about Amana NTW5100TQ Top Load Washer
What makes the water in the washing machine smell like eggs
    Problem Solver:
  • 3 Answers
Could ber that you use well water and are not use to it.
Posted on Jun 22, 2011
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
Smelly water with water softener
Your local home depot sells a product called AFFRESH that is made for front loaders to clean mold as well as stagnant water smells from washing machines. I have also hear other techs suggest vinegar and water but personally I would much rather have the unit smelling nice and flowery smell instead of a vinegary smell. Also it is important to note your drain line should be at least 6" higher then the top of your washer if it were less then the water that is supposed to leave the machine goes back inside the machine thus giveing some a stagnant water smell or like bad eggs.If you have any further questions message me back
Thank you
Rick
Nov 26, 2011 | Washing Machines
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
The washing machine smells!!
Run a load of just water and chlorine bleach. Run it HOT. After that, use bleach to clean the door seal and seat.
Apr 10, 2010 | Zanussi ZWF1640 Front Load Washer
Smells like rotten eggs
The smell of rotten eggs normally means you have some water that has been sitting arround awhile and has gone bad. You may have to unplug your machine and remove the front cover to take a look arround the inside of your machine to see if any water has leaked out and has puddled up. You may also have something caught in the drain pump's filter, which may have gone rotten from sitting around too long. This filter is easy to unscrew and gain access to once you have the front cover off. Make sure you have lots of towels or a wet vac handy when you unscrew the filter cover.
Jul 26, 2009 | Kenmore Elite 45986 Front Load Washer
After about 18 months, washing machine smells like rotten egg/fart. Is there anyplace to clean it out?
If you have well water, Check your "Annode" Rods in the Hot Water Heater. Had mine do this. I had to Replace the Whole thing as it built up to much Contaminents from the "Hard" Water.
May 12, 2009 | Washing Machines
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
Cant find my filter o a hotpoint first edition
i cant find the filter on my aquarius either, but i just read somewhere that this egg smell is probably caused by u mostly running the machine on cool washes i.e 40' ? so its suggests u run the machine on a 95' empty wash using ure normal detergent 2-3 times a year as the smell is a build up of bacteria because your washes arent hot enuff to kill it. If ure egg smell is bad, i'd do the empty hot wash thing a couple of times to make sure ! hope this makes sense?! :)
Apr 30, 2008 | Washing Machines
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Egg Smell
We fell prey to the same desire to have the state of the art, economical and supposedly gentler on your clothing front loading washing machine. Bosch WFK 2401 and I have found a solution but it is not pretty for those of you who have a washer not hidden in a laundry room.
I keep the kick plate off at the base of the front of the washer. Using a low profile pan, an 8 x 8 cake pan is about right and immediately after every wash plase the small drain hose over the pan and open it. The pan fills about half way with water that is left in the bottom of the drain system. Doing this prevents the next load from being exposed to the rotten egg water.
It must be done at the end of every load. I too keep the front door open when not in use and pull the detergent/softener draw open as well.
Good luck. Can hardly wait to justify that I have lived with this long enough to purchase a new top loader!
May 09, 2006 | Kenmore 24832 Top Load Washer
Amana NTW5100TQ Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
