Question about Minolta Di3510f Bizhub Copier
Why does it indicate that I can't boot up? - Minolta Di3510f Bizhub Copier
  • Norman  J Weimar Jr
    Norman J Weimar Jr Nov 21, 2015
    Hi wilopri24, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Any code s on the screen C-XXXX example!
  • Andrew Taylor
    Andrew Taylor Nov 21, 2015
    In English (roughly)
    I have problems with Minolta Konica Bizhub 3510. A sign on the panel that says can't boot up. I can do is nothing of that. thanks for the help
Hard drive activity LED indicator is red flashing , hp 4515s doesnt work
Blinking usually indicates activity as whereby some form of startup action is prompting the drive to boot. Failure to boot means the operating system boot sector is not starting and needs reinstallation of the OS.
Oct 19, 2013 | AMD Computers & Internet
Red light indicator on . It says "Boot Open" What is this?
"Boot Open" is how they say "Your Trunk is Open" in the UK.
If your trunk isn't open, then the switch that indicates the trunk is closed may be bad.
Sep 13, 2013 | 2002 Jaguar X-Type
Power failure,command display (no bootable cd)
It seems that your first boot was on cd or dvd, or may be your hard drive did not detect, to check both of them go to BIOS set up by pressing F2 or Delete on your keyboard to enter set up. When you are in set up mode go to Boot menu (if you can not see boot menu go to advance). In a boot menu select HDD as a first boot and Cd or DVD as a second boot, if you can not find your HDD it means that your HDD did not detect, and you need to replace it with a new one.
Hope it gives you a solution
May 30, 2011 | Computers & Internet
Why won't my computer boot to the A drive?
Because the BIOS is probably set to boot the hard drive first. The A drive, second or third depending on the boot order set in the BIOS.
Nov 23, 2010 | Computers & Internet
W350i (T-6836) No machine boot or boot-up
it seems capacitor blown up.
follow the steps:
1. check ur powercord & adapter.
2. if its working then check the battery, reseat the battery & check.
3. if available then check with another battery
4. if no, then remove the battery & switch on the PC in AC mode.
5. check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. if indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 17, 2010 | Gateway T-6836 Notebook
Laptop Not booting up, Scroll Lock indicator blinking
Your user guide might provide a mean to interpret the meaning of the blinking Scroll Lock Indicator...
May 09, 2010 | Fujitsu Siemens LifeBook® S7110 PC...
1993 makes a clanking sound and shimmies when steering to rights. Is that a CV joint or boot problem?
The clank (or more of a sharp clink) would indicate that your CV joint is bad on that side. The boot on the joint protects it against road dirt, etc. If the boot itself is torn, that's another indication that the CV joint is in trouble. Best to have it checked soon.
Hope this is helpful.
Oct 26, 2009 | 1993 Honda Accord
PC does not boot
Yes, and it may have some power problems, so check the power,battery,etc
Mar 26, 2009 | HP Pavilion dv6000z Notebook
76 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
