Question about Dolphin Maytronics Diagnostic Robot Cleaner
The light goes on and nothing happens. no sound at all. it was working fine two days ago. thanks
    President:
  • Dolphin Master
  • 1,378 Answers
Try a self test...flip the unit upside down on your deck and plug everything in a turn it on. Within 15 seconds it should start moving the tracks and the progress thru several track direction changes with and without the impeller motor turning on. After 30-45 seconds of these motions it will shut off and at that point I would put it back in the water and it should work.
If it will not perform the self test or will not operate after the self test it needs service.
For a list of service centers or further troubleshooting assistance please contact Maytronics directly at www.maytronicsus.com or 888-DOLPHIN.
John
Posted on May 20, 2011
Turn the key nothing happens, total loss of electrical
Please check all connections. Are lights/horn workings?
Aug 26, 2014 | 1995 Nissan Pathfinder
Philips 42PFL5405h/12 - Black screen and no audio on turning on.
It sounds that the settings have been corrupted. It will be best to contact the authorized service center to make this set right. Beware, not to make any experiments hereafter. It's 'PHILIPS'
Jun 24, 2013 | Philips Televison & Video
Hyundai Sonata 2004 turn signal does not work properly
did you check the directional switch. sounds like you have a bad one
Nov 07, 2012 | Hyundai Sonata Cars & Trucks
Dishwasher is a whirlpool DU940QWDB3. When yu press button to start washing, lights go on but nothing happens. Where should i start trouble shooting this? Thanks
Dear Sir:
see the wiring diagram attached.
1) I recommend the switch door, if are open the machine will not close the starting relais as you will see in the diagram.
sincerely. God bless you.
May 07, 2012 | Whirlpool Dishwashers
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Hi, I have Sony Bravia KLV-32S400A Couple of months ago suddenly get switch off after I switch on standby light(Red) gets blink. I unplug the power code and switch on the LCD after 3 hours it works fine. I...
Dear User,
in your case there is a supply fault..capacitor of power board is weak .kindly change the capacitor ..the sign of capacitor faulty is that capacitor is blow up like oil is coming out form upper side..kindly do the need ful.dnt use the lcd until the problem fixed.
Feb 04, 2011 | Sony Televison & Video
94 Sonoma 4x4 won;t lock into 4WD.
yea its not shifting again like before ? sounds like your transfer case solonoid has possably gone bad again .. these are a sometimes dont work item .. It is what shifts the transfer case into gear and it might be a little worn or weathered and not letting the switch kick it in gear all the way from the N position. thanks Jerry holler if you need more.
Feb 05, 2009 | 1994 GMC Sonoma
Ignition key turns on but car will not start
I suspect the ignition switch is malfunctioning.
Nov 19, 2008 | 2000 Ford Focus
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Dolphin Maytronics  Diagnostic Robot Cleaner Logo
432 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
