Question about Epson Stylus CX5000 InkJet Photo Printer
MY EPSON STYLUS CX5000INK JET DOESNT LET ME PRINT
I CANT PRINT ANYTHING IT SAYS PAPER JAM, BUT IT HAS NO PAPER. I CHECK EVERYTHING ALREADY ITS WELL CONNECTED. THE PAPER DOESNT GO IN THE PRINTER, IT WOUNT PULL IT IN. wHAT SHOULD I DO? WITH OUT GETTING A NEW PRINTER.
  • Anonymous Sep 12, 2008
    I have the same exact problem and the printer is not that old
I have no cd for my printer
Posted on Sep 25, 2008
Epson R265 paper feed problem
Paper feeder problem. You must open case and paper feeder.Check for all screw. spring, rubber and lubrication. If you never done, find diagram at printersiam.com. is printer paper jam berfore? and clearing jam by pulling paper form back?
Jun 28, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Printing on cd/dvds
you have to change the tray before you turn the unit on.
then check the paper path settings that you are selecting in the preferences. it should say CD/DVD on it, as well as the media type
Sep 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Paper jam
Usually paper jam error message on this machine is either caused by a physical paper jam or a printer error. To distinguish between the two I understand that you have already checked with the printer if there any paper or foreign object but there is none however, just to make sure you have checked everything out, check the left the side to double check. Now there is really nothing that you can see I really means that it is a printer error and that you would need to contact Epson directly to get a replacement. I do not recommend tearing off the printer because that's voids your one-year manufacturers warranty.
Jul 14, 2008 | Epson Stylus CX9400 Photo Printer
My C45 printer doesnt print anything inthe paper
Could be the jts are clogged in which you will need to do deep cleaning routine You will need to down load the ssc untiliy for for this - www.ssc.lg.com for this. or devise the cleaner syringe- see the picture.
Jun 14, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
