Question about Hotpoint HSS25GFP Side by Side Refrigerator
Refrigerator hss25gfta ww no power at the door lights water dispencer ice dispencer not working. replaced circuit board in the back no change
  • 2 more comments
  • semcclure651 May 19, 2011
    freezer door light switch works just fine. no lights on on the outside of the freezer door. temp. display is not lite, ice maker works the dispenser does not or the water will not work. it looks like no power going to the outside of the freezer door, and yes i replace circuit board on the back of the unit and no change?????
    no power going to the outside of the freezer door. digital display does not work , ice switch does not work, water dispencer does not work, inside freezer door light works as well as the ice maker. makes ice just have to open freezer door to get it out. replaced circuit board in back no change, checked wiring connection on top of unit by hinge, plugged in as well as the quick connect i the back of the unit
    that i believe is the only thing it could be
    President:
  • 2,047 Answers
The problem with your unit is most likely not the control board at the back as replacing it has brought about no change. Most likely the problem with your unit is the wiring which brings power to the door. The wires which run to the door and supply power to the lights and the dispencers to enable them function properly might have some inconsistencies therefore the flow of power has been cut off to the door. Although it could be the connecting switch which is not properly connected on one end or might have simply just disconnected. get an expert to trace the power supply to the door components and once that is done the problem should be solved.
Hope this solution has been helpful?
Posted on May 19, 2011
    Brigadier General:
  • 3,917 Answers
Possibility of the water valve solenoid on the back is bad. Also if freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch. Also if dispenser switch checks ok then it's the selector switch.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Ihave a model hss25gfta ww hot point refriderator. I had the power off while working on a light fixture. when I turned the power back on the refrigerator control for the ice box and freezer just blink ...
most like the controls frosted up in the ice box ... empty the freezer and leave the fridge unplugged for a while ... this will allow the frost to disolve ... plug it back in and it should be ok...
Mar 30, 2008 | Refrigerators
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Door dispenser
im not sure how old your box is,but if all is dead i think its new enough to have a board up there[water ice dispenser area].so its a matter of voltage .if you have the voltage need in the dispencer area and it dosen't work replace that board.if theres no power to the board go back to the next componet.which if t you have a board in the back you would test there,if you can find your wiring diagram that would give you an over veiw of whats going on in the wiring.iwish i could hit the eazy button for you on this one,see if that helps God bless ,tom
Jan 10, 2009 | Hotpoint Refrigerators
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
GE GSH25IHRB WW
My water line freezes. I have even had the door replaced and with the new door the line freezes. I use a hair dryer to warm it up and melt it. It's a pain, but saves me from buying a new refrigerator. (Which would definitely NOT be a Hot Point).
Feb 24, 2008 | Hotpoint HSS25GFP Side by Side...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
534 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
