Question about Ranger Pickups 19932010 Books
After installing rotors & pads on my 04 two whell
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 137 Answers
CHECK THE HUB ASSYS...THERES NO INNER AND OUTER BEARINGS ITS ALL PRESSED INTO THE HUB ASSY!!
Posted on Jan 11, 2014
Abs sound
Sometimes limited driving can affect the front brake pads and rotors due to corrosion, and dirt...inspect the pads for being worn unevenly...and the rotors for warping...the rotors would also cause the steering wheel to shake when applying the brakes...A small fix for a nice low mileage Ranger:) Hope this helps.
Jan 27, 2014 | 2007 Ford Ranger FX4 Off-Road
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
Brake esemble diagram
Hey Stan the man,need your vehicles info.,year,make,model and engine size and Tommy on the spot here will send you a picture diagram of your rear brake assembly.There's a special spring tool you can get at auto parts store to remove and install springs,me got one.
Oct 15, 2012 | Cars & Trucks
I changed front rotors and brake pads and now the abs light stays on. What is wrong?
You probably hit or pinched the switch or the wire of the left or right side.
Dec 24, 2010 | 2005 Ford Ranger
Abs/AWD light on 04 venture
Have you checked the brake fluid level?
Jun 06, 2010 | 2004 Chevrolet Venture Passanger
97 cadillac abs & traction control lights stay on after changing rear rotors and pads..
check for a broken wire to the abs wheel speed sensors. Also, one can replace the sensors sometimes.
May 03, 2010 | 1997 Cadillac DeVille
2003 Windstar brake light and abs light stay illuminated
I have had this scenario many times. It is usually one of two things...
1) Brakes are worn and need to be replaced (front pads/rotors)
2) One ore more of the ABS sensors are not reading correctly. This could be either a hub & bearing that need replacing, or just a sensor. It would need to be scanned and road tested to pinpoint the problem.
Jul 22, 2009 | 1987 Toyota Corolla 2 Door
My DSC and Brake warning lamps continuously light up in yellow once the engine has warmed up. They remain on after driving for a while and sometimes they shut off. Any ideas?
Check to see if your brake pads and rotors are in good condition. Or if you have replaced the pads yourself and have not reset the wheel sensors this would cause the ABS Antilock Brake System light and the ASC Automatic Stability Control light to stay on as the ASC uses the ABS brakes with computer assistance to control the car
Jul 09, 2009 | 2001 BMW 325
ABS and ASC warning lights stay on 2000 530d
Jul 06, 2009 | 1999 BMW 5 Series
Abs light stays on.
Typically on this model along with Q45's there is a built in sensor system. The factory pads come with a sensor, so when the pads are installed there is a wired plug that must be connected to the sensor mounted on the behind the rotor. This was designed to give you a visual warning that the brake pads needed replaced. However since most aftermarket pads for this vehicle do not come with sensors, the connector is left unplugged and the circuit is open causing the light to stay on. Another thing is to check the brake fluid level. Often times as the pads wear the fluid level goes down a little. Once it reaches a certian point it will cause the light to come on as well.
May 11, 2009 | 1997 Infiniti.5 J30
Ranger Pickups 19932010 Books Logo
47 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
