Question about Dell E173FP 17" LCD Monitor
My lcd stand get jammed..the bottom button is not working... what should i do?
  • 113 Answers
If your LCD is still under warranty, call dell technical support so that they can replace your LCD panel
Posted on May 19, 2011
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
How do you install tv stand
Are you talking about the stand that the unit came with or a wall mount? If you are talking about the original stand the unit came with all you need to do is lay the TV down on a flat surface making sure that it does not damage the LCD display ( the display is very delicate and can break very easily). You can lay the TV on a bed, carpeting or something that will not cause damage to the screen. Remove the 4 screws from the rear side bottom of where the stand goes unless the screws come inside a plastic bag. Slide the stand into the bottom of the TV and replace the screws to secure it in place. Then stand your TV up, make your connections and enjoy!
Apr 06, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I remove the stand from my LN-S1951W LCD TV?
The stands, from what I've personally seen, are usually attached with 2-4 screws on the back of the tv or sometimes on the underside of the stand. I've seen it even where the bottom piece of the stand pops off to reveal the screw(s).
Hope that helps :)
Nov 05, 2009 | Samsung LN-S1951W 19 in. LCD Television
The machaine jammed and now will not work. i have taken it apart and removed all of the jammed material. when the machaine is turned on, it goes stright into paper jam mode. There is an electric humming...
the machine still thinks it is jammed. the humming is probably the motor trying to turn, it can not beause it still has a jam? . you may need to remove the power cord from the wall. remove the shredder fro the stand. flip it over. remove the bottom cover and manual trun the cutting heads to unstick them. you may need a tech
Oct 21, 2009 | Office Equipment & Supplies
Stand by lcd stays amber, no power
i need to register my 47" vizio tv
Jul 15, 2009 | Vizio L32 32 in. LCD HDTV
How do I fit monitor Samsung SyncMaster932gw
just regix your bottom part of lcd there is lock system press top to bottom thenit locked.
Jan 19, 2009 | Samsung SyncMaster 932GW LCD Monitor
HP L1940 19" LCD Monitor
Hi...there,
It's open from the front bezel of the screen.. Place a piece of cloth or fiber cloth over the screen and carefully lifted up the bezel... do the same from other angles...
Dec 16, 2008 | HP L1940 19" LCD Monitor
Dell 19" Flat Screen Monitor
I have a DELL 2405 FPW. I had trouble the first time finding the button but it was at the very bottom of the stand under the cable channel. I'm pretty sure if it won't move up and down that it's locked in the down position. See if you have a button that will allow it to slide.
Nov 15, 2007 | Dell E173FP 17" LCD Monitor
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
Dell E173FP 17" LCD Monitor Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
