Question about GE Washing Machines
GE spacemaker washing machine - type 113-01 model #WSKS2060T1WB after wash, rinse cycle, machine drains and pump keeps running but will not go to spin mode. How to fix. thanks............John
  • toestring116 May 19, 2011
    Daniel S replied to my problem suggesting either the lid switch or the drain hose as the problem.
    The washing machine washes, rinses, and drains, so
    it cannot be the switch or hose. The drain pump keeps running when the machine has been empty of water for 20 minutes. It will not start spinning, for spin dry cycle............John
  • toestring116 May 20, 2011
    Macmarkus.............I didn't do anything to the washer, but it decided to start working properly.
    thanks for your input............John
  • GE Master
  • 2,605 Answers
Welcome to FixYa.
I've read your post and I guess the thing which comes to mind immediately is have you removed the front panel to insect the tranny or for signs of oil ?
You may not like to hear it, but on these GE if it will agitate and as long as it drains as you said it does, the problem is the transmission ( not the lid switch) and there will be oil all over the inside of the cabinet.
Let me know what you can and I'll try to help you any way I can. i.e. removing the front panel etc.
Regards,
Macmarkus :)
Posted on May 19, 2011
  • 4,323 Answers
Hi
First you can check the drain hose; it should be upright position, check and correct the drain hose assembly. If that is fine and still it keeps on running then check the lid switch before replacing the pump. Hope this helps...please post back for further assistance.
Daniel
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
When the washer gets to the spin cycle it seems to stop and not pump out the water. All other cycles seem to work ok. It is a GE spacemaster 22"
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Washer does not drain , rinse or spin
most common reason is the water pump has failed the unit will not spin untill it detects all the water has gone some times the motor is jammed take it off and look for a small coin or something thats stopping it if not then you may need a new pump motor
Apr 20, 2010 | GE Spacemaker WSLP1100D Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washing Machines Logo
114 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
