Tractor dies and will not charge battery. i installed new battrey new starter and newsolenoid
  • 2,510 Answers
If the battery runs flat the problem will be the charging system, ie. the alternator.
To check your charging system. With the engine running at about 2000 rpm, a volt meter across the battery terminals should read around 14 to 14.5 volts and drop to about 13.8 volts with the engine at idle. If this does not happen, the charging system may be defective. Even with lights on the voltage should climb, but will drop lower at idle. If the battery is defective, with the lights on and the engine running, when you rev the engine the lights will shine brighter. For now I suggest that you have the alternator checked by an auto electrician. Good luck and please rate this response.
Posted on May 19, 2011
What would drain a new battery on 2n
I would install a shut-off switch in postive cable of battery
till you the problem.
Jul 27, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
New battrey installed. Fired up no probs. went for a run and it just died after 30 miles. battery flat i know, why? Is this the altirnater? Coil?
charging system is suspect, at risk of demining you you need to take it to be checked , as with you asking this question you do not have the mechanical skills to check it yourself sorry but it will cost less in the long run.
Aug 05, 2011 | Yamaha YZF-R1 Motorcycles
Unable To Charge Message on Razor Cell Phone stops working off charger. Battrey shows full
My v3 has done the same sometimes I couldn`t charge then taking it off charge it used to die.
Try a new battery.
Nov 09, 2009 | Motorola Mobility RAZR V3
Charged battery but battery shows empty
my nokia 1100 charging full but battrey low plz solution
Oct 16, 2009 | Cell Phones
Altinator dose not charge when battry is low
time for another battery. Have a load test done on battery. Then have someone fullfield the alternator to see if its operating correctly
Jul 13, 2009 | 1987 Toyota Land Cruiser
Motor willnot start. clicking noise when i try to start it. the battery is good and i jump started it with my car--started great. i have cleaned the posta and cables
the problem is the starter cylinoid . this is going to set you back about 10 to 15 dollars.
or it could be your starter trying to go out, it will crank off your car battery because you are using more amps to crank it..
a car battrey has more cranking amps than a small engine battery..f.y.i.
Jun 24, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Truck turning-over when jumping battery
if you replace the alternator im sure it will be fine while your driving the battery is not getting charged so thats the only thing that it could be
Oct 27, 2008 | Ford F-350 Cars & Trucks
42 people viewed this question
k24674
jasbo
jasbo
