Power supply collapse - Televison & Video
  • 325 Answers
Repair by using SAME uF value and HIGHER Voltage rating on the new capacitors.
Example: 1000uF 10v---->1000uF 35v!
Good luck!~
Posted on May 19, 2011
Where to i get replacement parts for Tour Trek collapsible golf cart
contact golf supply shops
get the manufacturer web page up and check for spares
Aug 21, 2014 | Tour Trek One Click 2.0 Collapsible Push...
Issues with xantrex dr series inverter
Make sure the battery connection is solid, if the 12 V collapses at the inverter -> no power. If that is OK, make sure to apply first a known good load, like a light bulb, if that still causes a problem the inverter is broken :-(
Apr 19, 2014 | Xantrex Technology Xantrex DR Series...
The hose on my accuspray turbine Hvlp system is collapsing once it gets hot. Do hoses wear out like this, and can I replace re hose with a standard garden hose, or do I need to buy an accuspray hose?...
The hose supplied by Accuspray does soften as it warms up but should not be collapsing. Most hvlp turbine system manufacturers supply a hose with a helix reinforced hose that will not collapse.
The majority of hoses for hvlp systems are 3/4" inside diameter hose like the Accuspray hose and will work with your system.
The fittings will work with any 3/4" garden hose. Problem with using garden hose is that the cheap ones will collapse and kink and the quality ones will be heavy.
May 31, 2011 | Garden
No power
try to remove the cables and battery on your laptop. Then press and hold the power button for 8secs. Then reinsert the battery and cables on your laptop. Turn on the laptop and observe if the power light is on. If it is still off, there are 2 technical issues to be resolved. One is that the circuitry on the motherboard is not repsonding, that means you need to contact your laptop provider to replace the motherboard. Another one is that the power supply of it is not responding well, again you need to contact your laptop provider for such...
Oct 17, 2010 | Computers & Internet
Sony kv 35s36 won't come on at all. No click, sound, hum, buzz, nothing.
blown power supply.... I have the same tv... but with a fault in the main board leaving me with a flashing image. I have a power supply that's good and you have a main board that's probably good.....??? function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
Sep 11, 2010 | Sony KV-35S36 35" TV
Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Jul 13, 2010 | Casio Music
Turn on TV, no picture but sound is ok, thin white line running across screen
You have a frame collapse problem. Line, EHT, power supply, video and sound stages are all functioning. Check frame output ic for dry joints, resolder all pins. HT supply for output ic's derived from line stage check for open circuit safety resistors around line output transformer, if you find any then frame output ic will also be suspect. WARNING Very high voltages exist around the line stage. Make cold tests with Ohm meter with set unpluged from mains supply.
Feb 27, 2010 | Toshiba CN36X81 TV
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
Intermittent collapse or rolling of TV picture
Look for dry joints very carefully in the vertical circuitry, IC and the power supply
Apr 07, 2009 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
