Question about Roper RTW4300SQ Top Load Washer
Water leak under machine - Roper RTW4300SQ Top Load Washer
  • 5,911 Answers
A leaking washer can have several causes. In order to be able to accurately determine where the leak may be coming from, you will need to remove the exterior washer case to get a full view of all the interior washer components. If this is a TOP LOADER, the following link explains how to perform this procedure and what to inspect for:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
From the symptoms you have described, it sounds like you may have a leaking drain pump. These pumps are not serviceable, and if leaking, they must be replaced. The following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The average price for a pump is about $35.
NOTE: Roper washers are manufactured by Whirlpool, so these instructions do apply.
If you have any questions about any of these procedures, please post back and let me know. I hope you find this information helpful.
Posted on May 19, 2011
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Maytag MHWE201YW Laundry : Front Load...
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Leaks when filling with water
Check with espressopartsnw, they have a large selection of parts, if you cannot find it under wega look under astoria or rio same machine.
Sep 08, 2009 | Wega Mininova EPU Espresso Machine
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Water leaks under machine
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Mar 02, 2009 | Admiral AW22 Top Load Washer
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Roper RTW4300SQ Top Load Washer Logo
61 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
