Question about Dell XPS 410 PC Desktop
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and installed the 2x2gb RAM. system boots but shuts down after 20 min or so , with high fan sound. So, i remove the 2x2 GB ram and put back the 512 MB. Now, i am got into the loop, Boot manager screen comes up and says No boot device found.. "Insert windows installation CD", "Repair the sytem" and restart. Even i repair , from backup it says restored succesfully and get into the same loop when restarts. goes to Boot manager screen and says Insert Windows installation disc... Any help would be appreciated. Thanks Much!
  • ramkumar_sar May 19, 2011
    Thanks for your response! In the DELL user manual, it is specified it can be upgraded upto 8GB RAM , 2GB max each slot. and i bought curcial after their on line diagnostic test. it is DDR2 PC-5300. But, after i reinstalled the old RAM it doesnt work. If i have demaged the RAM Slots is it replaceble ?
  • 37 Answers
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
Posted on May 19, 2011
    Thanks for your response. The DELL user manual said it can be upgraded to 8GB RAM . And i found the right RAM, Crucial 2 GB DDR2 PC5300 which is recommended. If i demaged the RAM slots (I didnt touch anything else), is it replaceble?
I m not a hardware engineer. But I like to share some information here about Dell XPS 420.Take a look of below link :
http://www.pcartisan.com/dell-xps-desktop-could-be-powerful-digital-media-nerve-center.html
Posted on May 24, 2011
  • ramkumar_sar May 24, 2011
    Thanks! The link didnt work.
    I took out all the RAM and re installed it (the old RAMs came with the system) and it is working now. but ended up installing the WHS 2011 again from the scratch and configured. that fixed the issues.
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
My Dell XPS 420 will not turn on. Power light shows a steady blue color. No diagnostic lights show up.
The RAM maybe faulty.
Try resetting the RAM modules to make sure it is seated correctly in the memory slot.
If the computer still does not boot up then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them tested. If faulty then replace the RAM.
Feb 25, 2012 | Dell XPS 420 PC Desktop
I have a dell xps 420 and its infected with some form of spyware. my issue is getting it to run in safe mode... i have no clue on how to do this. most site explain the use of f8 at startup and it should go...
To enter safe mode you must press f8 right before the Windows logo screen. In my experience the best way to achieve this is to tap the f8 button repeatedly when you turn on the computer. F8 is the correct button for Windows operating systems, the guides were right, you might have just not pressed it at the right time.
Apr 22, 2011 | Dell XPS 420 PC Desktop
My Dell XPS 420 restarts itself whenever i play games on it
You might need a new Graphics card and a 400 w power supply. also, try cleaning it (the fans and HS's
May 13, 2010 | Dell XPS 420 DESKTOP - Intel?® CoreTM2...
Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Apr 29, 2010 | Dell XPS 420 PC Desktop
Upgraded Studio XPS 435/9000 Ram - Now No Windows 7 Start
Check speed settings in BIOS, make sure that the sticks are the correct voltage for your motherboard. If the specs are correct, try a program like memtest86. This will tell you where the problem is, but it is up to you to find which stick that location is :) Might take some trial and error before you find the defective one!
Dec 15, 2009 | Dell Studio XPS Desktop Computer
I have installed 4 GB of RAM but it only shows 3 GB RAM
Any 32bit OS can only read up to 3.5GB of RAM. In order to read additional ram you must have a 64BIT OS.
Sep 27, 2009 | Computers & Internet
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Windows doesn't see my 6 GB of RAM but BIOS does
You have the same machine as i. To the best of my knowledge it does not support 2 gig sticks. Thats why the say it only supports 4 gig of ram. I hope that is correct still. I also do not have a12 Bios so it could have changed.
Mar 21, 2009 | Dell PowerEdge 1600SC Server
Dell XPS 410 PC Desktop Logo
265 people viewed this question
Alun Cox
