Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
My kenmore elite will not start - lock on button stays lit and no other buttond work
  • Kenmore Master
  • 3,361 Answers
Push and hold the lock button until the light goes out.
Posted on May 19, 2011
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control lock button is lit - we can't start the washer...
Aug 01, 2009 | Kenmore Washing Machines
Contol Locked
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Controls locked
Hello
Welcome to Fixya
My name is Huum,
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
170 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
