Question about Frigidaire FEF326 Electric Kitchen Range
My electric frigidaire stove will not come on at all.what do you think the problem is? the power on light wont even come on.
  • Frigidaire Master
  • 3,361 Answers
Check your fuse or breaker panel for a blown fuse or tripped breaker.
Posted on May 19, 2011
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
I have a Frigidaire ES 100/105 electric stove that is about 1 year old and has just stopped doing anything - no lights, no heat in stove or on stove top. nothing. I have power to the outlet so it is
Hey friend, I appreciate your post! It sounds like a possible issue within your control panel or a faulty wiring harness. I would recommend seeking assistance from a professional for further proper diagnosis and repair to avoid any unnecessary part purchases. If you need any additional assistance please feel free to reconnect. -Matt
Oct 10, 2014 | Frigidaire Kitchen Ranges
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
I have a frigidaire PGLEF385CB1 range, after an electrical strom the oven stopped working. before I even call a repairman. what is the most expensive thing it could be and what is likely to be the issue?
Was your stove on during the storm have you checked the electriclal breaker to the stove? I cant imagine the whole stove going out perhaps this unit has a common power module
Apr 09, 2012 | Frigidaire Kitchen Ranges
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Sep 17, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Frigidaire FEF326 Electric Kitchen Range Logo
128 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
