Question about Microwave Ovens
Hello, I need a microwave mounting bolt that is at least 6 inches long. Can you help?
  • 2,510 Answers
You should be able to buy bolts that long, depending on the diameter, but for mounting a microwave I would suggest you go for 5/16' (8 mm). If you cannot get bolts, use threaded rod and cut it to the length you need, using washers and nuts on both ends to create your long bolts. Most better hardware stores will stock the threaded rods but long bolts may be stocked by fastener merchants only. Good luck and please rate this answer.
Posted on May 19, 2011
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Apr 05, 2009 | GE Microwave Ovens
NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Nov 15, 2008 | GE JVM1190 Microwave Oven
My 87 year old mother just bought a new Maytag over-the-range microwave model MMV1153BAW. The bolt that came with it is too short to install it into her cupboard configuration. She says it is a #6 metric...
She may need to buy a length of "all-thread" of the right size, cut it down, and then add two nuts to the tool end so it can be turned and installed.
If you're not sure, you can ask about it at the hardware store, and even show them the attached photo.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Microwave Ovens
No studs for microwave installation
There has to be something in the wall supporting the drywall. You need to find the supporting structure using exploritory holes if necessary and solidly fasten to it using lag bolts.
Jan 11, 2008 | Microwave Ovens
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
