Question about Toshiba E-studio 281c Copier
Hi my name's Alberto, sorry for my bad english, I hope you understand anyway. I have a e-studio 281c with a problem on display appears: -- READY (toner not recognized) me and my colleagues had change one at a time o we did this : toner cartridge BK - C-M-Y (original) - reset NVRAM - change NVRAM - change micro-interrupt sensor of toner cartridge presence - change motor/gears assembly of motion of cartridge - change PCB LGC - change PCB SYS - checked wiring continuity - change memory dimm but it did not do anything. Suggestions??? Thanks, best regards
  • 60 Answers
Try to shake the toner cartridge well & clean the board at its end
Posted on May 23, 2011
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Can I join a Toshiba 281c to a home group network?
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Feb 22, 2015 | Toshiba E-studio 281c Copier
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
I need to calibrate the display screen on a Toshiba e studio 281c
Hi: Hold down the 0 and 8 keys while turning on the copier. Do not release them until the extension light comes on. This light is located above the display. Once this happens key in 692 and press the start key. You should the see two arrows in the upper left and lower right corners. Press each one of those to calibrate the screen. Shut the copier off and turn it back on and you should be all set.
Regards
Andrew
Nov 01, 2013 | Toshiba e-Studio 202L Copier
I have a Toshiba 281c and a few days ago the display started acting up. Now when you power up the machine the display lights up but has no text or menus on it. You can't change the functions it is stuck on...
try to enter service mode by pressing 08+power on
enter code 1501 you will see 2 sighns "+" on display
by using plastic stick you can calibrate your display
just touch this "+" jently
then wait few seconds till calibrating process
Good luck!!!
Mar 13, 2011 | Toshiba E-studio 281c Copier
Mintek tv
OTREBLA36:
Alberto, your english is fine!
If your TV\DVD player is not damaged, then u have to look to your DVD disk. A smouge, a finger print, your or anybody Holding disk the wrong way prevents the light that comes out of the DVD to hit or touch the disk, causes it not to work or FREEZE.
1ST CLEAN ALL YOUR DISK with a DROP!!! of liquid soap in a small cup of water.Place a clean towel [NO LINTS on towel] in cup,squeez water out and clean GENTLY from LEFT to RIGHT, UP and DOWN.
Alberto, Its important that you DO NOT clean in a circle!!
[up and down, Left & right]!!
Question:: " all disk freeze "??
Get a different disk NEVER used in that machine.( try it!)
May 12, 2008 | Televison & Video
Toshiba E-studio 281c Copier Logo
368 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
