Question about Lexmark Z816 InkJet Printer
How to I shut off the audio voice commands - for example "printing started" "printing complete"?
  • Official Brand Answer
  • 3,344 Answers
Go to Control Panel > Printers & Faxes > right-click on the Lexmark printer print object > Properties > Advanced > Printing Defaults > in the Lexmark Printing Preferences windows, go to Advanced tab > More options > select Never show the Printing Status window or Printivity Tips. > Hit Ok > Click Ok again > Hit Apply > Hit Ok again.
Posted on May 31, 2011
Sx125 epsom not printing complete pdf, text missing
It appears that the blanks you are getting are purposely being set by the company. They have those blanks "protected". You will probably need to contact the airline technical department to get the code to unprotect those blanks!
Jan 02, 2013 | Office Equipment & Supplies
What is "time out" setting in voice prompts
When you try voice command and you cant speack any thing or sound is not clear than time out will appear If your voice is clear than your command are not found... Just try other word
Sep 11, 2012 | LG VOYAGER VX10000 Cellular Phone
Naka online yung printer pero pag nag na click na yung PRiNT . nka "" OFFLiNE "" ?
You may need to re-install the printer drivers; but before you do that, first go to the command prompt:
(1a) For Windows XP: Click Start --> Run --> Type CMD --> Press Enter
(1b) For Vista or 7, go to Start and type CMD directly in the Search box
RIght-click on the cmd icon that appears under the Programs list and select rictutero_13.jpg as seen above (If a User Account Control window comes up, click YES)
(2) In the command prompt that opens up, type NET STOP SPOOLER and press Enter
(3) Wait for the command to finish, then type NET START SPOOLER and press Enter
(4) After the command completes, you can retry printing. If it still fails, then you will have to re-install the printer drivers.
(5) You'll have to insert the printer drivers disc: it usually runs the installation immediately & these applications can detect if you already have it installed. You will be prompted to remove the software; after which you can repeat the process (step 5) to re-install the application and try printing again.
If all these fail, you would have to test the printer on a different computer to see if it exhibits the same symptoms. If they do, then the printer will have to be checked for possible repair/replacement. If not then there's something wrong with the operating system on YOUR computer and it will have to be checked separately.
Aug 14, 2011 | Computers & Internet
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
T-Mobile Dash Voicecommand: What keyboard keys map to the "app1" through "app6" keys in the Voicecommand application?
The key to use for voice commands is the HOME BUTTON. This is the button that has the shape of a house on it, to the right of the green send key. Set the app to none or app 1, and it should work. It has only worked a few times for me though; it is kind of confusing. So, good luck. Also, there is an online voice command help. Go to voice command, click menu, click help.
Feb 10, 2011 | T-Mobile Dash Smartphone
Print job(s) waiting in queue will not advance to print.
If there are no errors with the printer (offline or other issues), you may have a problem with the spooler. You need to stop and restart the service. One way to do this in Windows is from the Command Prompt (Run As Administrator for Vista or Win7). Start > All Programs > Accessories > Command Prompt (right click on the option to Run as Administrator).
At the first prompt, type "net stop spooler" without the quotes and hit enter. At the next prompt, type "net start spooler" again without the quotes and hit enter. (Type Y if you get a query about the Fax system after the first command.) When the second command completes, reboot the computer and try printing again.
I hope this helps.
Jun 11, 2010 | HP PSC 2175 All-In-One InkJet Printer
Can't cancel print from spool
Try forcing the spooler to stop and restart. In the command prompt (Start > All Programs > Accessories, right click and choose run as administrator with Vista and Win7)
Type "net stop spooler" <enter> without the quotes; on the next line type "net start spooler" <enter> again without the quotes. Once another prompt comes up, restart the computer.
I hope this helps.
(without the second command, the phrase "go get a cup of coffee after the reboot" becomes a part of the routine. These commands have worked since Win95.)
Apr 18, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
Lexmark Z816 InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
