Question about D-Link DIR-615 Wireless Router
Hi, I have a D-link DIR615 Router version D2 connected to Virgin's 50mb service. After encountering a bad virus, I had to fully re-install windows xp on my PC. When I reconnected my modem and router and checked my network settings, I discovered that although everything was powered up (all lights on and a connection status confirmed), all my details had disappeared as follows... Address type: IP address: subnet mask: Default gateway: All of the areas appear blank on my PC as above. This has left me unable to connect to the internet through this set up. Apologies in advance if this is not a D-link problem...I'm just trying to narrow down the cause and sollution. Many thanks in advance, Mark
  • 60 Answers
Since you have re-installed Xp try checking device manager. You should see network adapters there. If you do not see it, it means the software for it is not installed. You have to download the drivers from the computer manufacturer's website.
Posted on May 19, 2011
I keep getting kicked off
Try changing your wireless channel to 1 or 11 to see if that resolves the problem. You can access the router page if you need help logging into your router.
http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
If that doesn't work, I think calling them is the correct course of action. number is 1-800-255-3700. they are open from 6a to 7p PST, seven days a week.
Jun 12, 2012 | D-Link Dlink Dir-615 Cable/dsl Router...
I mistakenly plugged in 9V power to my D-Link DIR615 router?
Most likely you have damaged the D-Link router.
Connect a correct power adapter to the D-Link to see if it works properly, if it doesn't work then you need to purchasr a new wireless router.
Feb 26, 2012 | D-Link DGL-4500 Wireless Router
I have a D-link DIR615 Router/switch. Intermittently (i.e. several times per day) the router looses connection to the internet (although the internet connection light stays green), or I loose the local...
Download and install the firmware update
http://www.dlink.com/products/default.aspx?pid=DIR-615&tab=3
Make sure to download the one for your specific model, and do the flash via a wired connection.
If no change, most likely a new router is in order
Jun 20, 2011 | D-Link DIR-615 Wireless Router
Just got a dir615 from virgin media. lan to pc not working
If the lan light does not light up, there is a problem with the connection between the pc and the router. Did you use the cable between your modem and your pc as the cable between your router and your pc? If so, it may be the wrong cable. With some modems the suppler sends a cross over cable. This will not work between your router and your pc. Get a straight through cable and try that.
If that does not work, we need more info to help you more.
1. What is the IP address set to on your PC. See the TCP/IP properties listed in your network connection properties in the control panel.
2. Does your PC work with the modem directly?
3. Does the cable you are using have a cross-over label on it?
4. Are you trying initially to connect to the router via a wireless connection? You should use a cable connection to set up the router, then try the wireless connection.
good luck, and if any of this solves your problem please leave feedback. Otherwise send more information.
Feb 05, 2010 | D-Link DIR-615 Wireless Router
WHERE DO I DOWNLOAD THE SETUP WIZARD I LOST THE CD
Please follow the below link to download the drivers for your router.
ftp://ftp.dlink.com/Gateway/dir615/Apps/RouterSetup_dir615_410.exe
Its a direct link so you will just need to hit the link and drivers will download.
Cheers
Nov 04, 2009 | D-Link DIR-615 Wireless Router
I have a d-link router model:DIR615 but I lost the cd is there any other way to intall my router not using the cd or can the cd be download from somewhere?
Yes there is a simple solution. Go to the D-Link website and look for driver downloads. That is what you will need to download and install then connect the router and presto you should be back in business.
I kill goats for satan!!!!!!!!!
Aug 15, 2009 | D-Link DSL-G604T Wireless Router
What are the settings for windows 98 for d-LINK DIR615 ROUTER
In control panel, find the network applet and double click it. in the white box, locate TCP/IP(Internet Protocol) and select that, then click properties
Make sure you're set to DHCP which should, once you're physically connected to your router, obtain an IP address and DNS server addresses automatically
Mar 03, 2009 | Microsoft Windows 98 Second Edition for PC
Cannot finish connecting
Hi fozzy211 - Please don't rate this 'til were finished. You've got two things going on. You said it's telling you to check the cables and then you say it's saying the router isn't from Verizon. Is it both? Are the cables hooked up correctly to your knowledge? We can fool Verizon's system. Let me know if you actually have two problems. For now I would only hook up one pc via wired until it's working. I'll await your response. Thanks.
Jeff
Jun 04, 2008 | NetGear WGR614 Wireless Router
Cant connect to cable
Hi Snuggles,
Make sure your networking permissons are setup properly, on the Vista. Since it varies with what version Vista you have, try this link.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
Great help site for Vista. Click on the Network tab, follow the info to setup your networking, and if you are still having issues, got to the troubleshooting. Please make sure you doing your setup with a cable, too, not over the wireless.
Good luck
Jan 10, 2008 | NetGear DG834G Router
D-Link DIR-615 Wireless Router Logo
91 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
