Question about Garden
The process of creating CD has some problem and stopped
  • 2,510 Answers
You do not give much information, so I assume that your problem is software related. Try another burning program, such as ImgBurn, it is freeware and can be downloaded from the net. It is easy to use and works very well. Ashampoo Burning Studio is also very user friendly but is not freeware.
Posted on May 19, 2011
Create system suite account
When you insert the 1st CD it should start up the install process and ask you for your Registration ID. Just enter that and it will proceed.
Jan 01, 2014 | Avanquest Software FixIt Utilities...
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
Hi I want to create a system restore cd for my Toshiba laptop model A105 S2051 its a satellite. I really dont know how to create it since when I bought the system I sorta forgot to create it then. Would...
Go to Start, Programs or All Programs (depending on your OS), then Accessories, System Tools, and click Backup.
A Wizard welcome screen will open. In this screen, click the underlined words for the advanced mode. This will open a tabbed screen. On the Welcome tab, choose the Automated System Recovery Wizard. Another Wizard will open. At this screen, click the "Next" button.
Insert the CD into your CD-burning drive. Double-check the file path and make sure the computer correctly searches for the CD burner. If it does not, click the "Browse" button, find the burner and click "OK." Once the correct path is in, press "Next." At the final screen, click "Finish." This begins the process of creating your restore CD.
Dec 13, 2010 | Toshiba Sattelite A105-S2051 Notebook
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
Unable to reinstall windows xp
try it again with the bootable floppy disk... if you have the option use fdisk /mbr and then format the computer and reinstall using the cd you have. the fdisk /mbr command will get rid of any virus residing in your master boot record.
May 24, 2009 | Microsoft Windows XP Home Edition
My laptop stops responding, automatically restarts and displays a message "operating system not found". I've tried to repair my os but still it can not boot, what do i do?
first change ur booting option from hard disk to cd rom and then boot the window cd and at the time of instaling window delete the all partitions and then create fresh partitions and then format the partition and then instal the window. i am sure that this process can remove ur problem...........
Mar 31, 2009 | Microsoft Windows Vista Home Premium with...
Restoration disk
Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
1. Plug in the AC adapter.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4. A screen stating "Starting Acer Erecovery" should appear.
(Release ALT and stop tapping F10 at this point)
5. There will be 4 options:
1. Restore system to factory default
2. Restore system from user backup
3. Restore system from cd/dvd
4. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
1. If recovery cd/dvd's were created, they can be used to restore the system.
2. Insert disc 1 and follow the prompts.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
