Question about Brother Office Equipment & Supplies
Brother HL 4570 CDW Smears ink when printing on card stock.
  • 624 Answers
SOURCE: Brother HL 2040 Printing problem
Ninamat, If this doesn?t work for you supply us with some additional details such as how the printer is connected to your PC and we?ll try to help.
Posted on Mar 01, 2007
  • 108 Answers
SOURCE: Brother HL 1440 Printer Density Adjustment
Go to Printer and Faxes and select the properties button, then select the maximum dpi in the Advanced tab. You will get the best quality Print
Posted on Feb 08, 2008
SOURCE: Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Posted on Dec 16, 2008
SOURCE: Text is "ghosting" when using card stock
I sort of solved my ghosting problem by selecting print, set up, and then under media type selected thicker paper. This apparently pulls the card stock through at a slower rate which helped tremendously. One of my documents turned out perfect and the other "ghosted" just a little.
Posted on Dec 18, 2008
  • 19 Answers
SOURCE: What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Posted on Oct 11, 2009
Testimonial: "I had no clue what a waste toner box is. Your response helped me. Thank you."
Can I print on card stock with Brother HL-L8350CDW?
In your print settings change the media type to Thicker paper, go to advanced settings and set your other print options settings to improve print output and click improve toner fixing. This will max the fuser temperature but will produce some curling so flatten the product while it is still hot
Dec 12, 2017 | Brother Office Equipment & Supplies
My black ink doesn't print well despite changing cartridge and ink smears appear on the image when printing. What can I do?
have u gone through the re-alignment process and clean print heads as u should do it after every change.
May 19, 2015 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
I recently made my canon iP2770 a continuous ink one. It as going well, untill it said "The holder is in the ink cartridge replacement position.Close the printer's cover.Ink has run out. View the
Throw it in the trash and buy a laser jet.
People who print a lot, and do I, would be better off buying a new printer every time I went to buy cartridges.
The printer I bought was a brother HL 3140 cdw.
~$200 at staples
The cartridges are expensive ~$200 and lasted me for a year.
I said a year!
Jan 27, 2018 | Canon PIXMA iP2200 InkJet Photo Printer
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
We have a Brother HL 4070 CDW printer and it's leaving black smudges down every printed page. We have tried vacuming it out, but that did not help the smudges. Any ideas?
Hi there !
this is a commun problem for all the printers, you should clean you printer's inside !
for that printer you habe to check all the way where the paper moves.
Aug 20, 2010 | Brother Office Equipment & Supplies
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
Dec 17, 2008 | Brother HL-2070N Laser Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
153 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
