Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My Kitchen aid refer model # kscs25inss00 ice maker is not working. I've tried power off and on. Water in the door work though.
  • 8,197 Answers
I have seen this many times.
You will need a new ice maker module assembly, it comes in a kit that has been upgraded.
Here's the one for your model:
Manufacturer part#8201515 is RepairClinic item#961550
It will come with manual to remove and replace.
Posted on May 19, 2011
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kitchen Aid side by side model #kscs25inss00 The ice machine stopped working. I checked the solenoid valve for the ice machine and it works, as does the water dispeser in the door. The teeth in the ice...
First off is the water filter bad and or do you have one...if not and it is good...then you have pretty much diagnosed the problem correctly...as you said the old Ice maker gears turn and when they make a complete revolution they engage a trigger which signals the water solenoid to dispense water to the ice maker...another test is to fill the ice maker manually and see if it freezes (test the temp of the freezer...if it is not cold enough the ice maker will not work)...if ice is made (generally under 4 hours ) and it is not dumped...you need to replace the Ice maker...around $30 to $50depnding on brand and where you buy it...I shop Marcones Appliance parts the appliance repairman's friend...good quality cheap prices.
Good Luck I hope this helped...please rate me ...the Fang.
Mar 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Red light on ice maker blinking twice, no ice.
I would assume you are referring to the ice level sensor that is on the center divider. It is normal for it to blink if the door is open. You can test out this theory by holding the flap on the left side closed but not blocking the sensor. The light should go steady. If the ice maker is not working then you either need to change the lazer sensor or the ice maker itself.
Feb 01, 2009 | KitchenAid KSRG25FK Side by Side...
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stop working
YES ... MOST PROBLEMS WITH ICE MAKERS THAT SUDDENLY STOP WORKING IS THE WATER SOLENOID STRAINER IS CLOGGED OR THE ORFICE INSIDE IS CLOGGD.(USUALLY LOCATED BEHIND THE FRIG. WHERE THE SMALL WATER LINE CONNECTS). THE STRAINER AND ORFICE IS USUALLY ON THE "INLET" SIDE OF THE VALVE.WITH BUCKET AND RAG NEAR-BY, TRACE THE SMALL WATER LINE AND LOOSEN EACH NUT TO SEE IF YOU HAVE WATER. SOME WATER SUPPLIES USE A SMALL "SADDLE VALVE" FOR TAPPING INTO A WATER LINE. THEY CAN CLOG TOO ... YOU CAN TEST TO SEE IF THE SOLENOID VALVE HAS POWER TO IT ... BY TAKING A METAL BUTTER KNIFE OR NAIL FILE AND HOLDING IT CLOSE TO THE TOP OF THE SOLENOID (coil) YOU SHOULD FEEL THE MAGNETIC PULL IF IT IS ENERGIZED. IF IT IS ENERGIZED AND YOU HAVE WATER ALL THE WAY INTO THE BACK OF THE FRIG ... THE PROBLEM LIES SOMEWHERE ELSE.
Apr 28, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
157 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
