Question about Garden
What are the valve cover torque specs on the Cub Cadet LT1045 18.5 HP Kohler engine?
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
mickey813
  • 472 Answers
SOURCE: Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Posted on Oct 12, 2009
  • 66 Answers
SOURCE: my cub cadet 682 with a 17 hp kohler was running
Are the points set correctly? Check the gap....you said it was running like **** to start with...it maybe a carburetor issue.
Posted on May 30, 2010
  • 13 Answers
SOURCE: cub cadet LT1046 will not start. Battery shows 13
This is most likely a ground problem. Remove the ground wire where it goes to the battery terminal and make sure it is clean. Then remove where it bolts to the frame and make sure that end makes contact with bare metal.
Posted on Jun 10, 2010
wilsodfarm
  • 986 Answers
SOURCE: Cub Cadet Riding Lawn Mover with Kohler Engine -
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Jun 15, 2015 | Cub Cadet Garden
What is the cylinder compession on a kohler 16 hp comanderfrom a 2004 cub cadet
I would hope to get about 90-110 of compression. If you get more great. If you get much less you will have to open the engine and see what's going on inside. Possible piston, valve or rings. GOOD LUCK FRIEND.
Feb 23, 2015 | Cub Cadet Garden
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
Only runs with choke on Cub Cadet 19 hp kohler
Carburetor probably needs cleaning and carburetor rebuild kit installed. You need a local that can determine which kit you will need based on the engine model and spec number.
Aug 19, 2014 | Garden
Flames come out muffler
Sounds like Intake valve gap is bad and there is gas in the oil ? Valves cleaned, lapped and head gasket redo . Not too spendy. About 25 dollars total for everything. The lapping tool & Compound, head gasket, OHV rocker cover gasket if equipped. Maybe an 'inch pound' torque wrench if you don't have one, misc socket set, rags, carb cleaner, starting fluid for the tougher build up and some new steel wool pads. Also the valve clearance specs on rocker arms and a few how to vids on youtube about adjusting your valves with feeler gauge and proper torque specs are listed in your engine's model number Manual online somewhere.
Jul 11, 2014 | Cub Cadet Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
Kohler lawn mower wont start just backfires
remove the valve cover and make sure the valves are working
Jun 24, 2012 | Mtd Cub Cadet 46 In 20 HP Kohler...
Looking for cylinder head and connecting rod torque specs for a Kohler K582 engine
hi there
pauly 46 here
for your information required see the download of service manual from below
http://www.scribd.com/doc/3852484/K582-Service-manual
but i have the required settings for you in the mean time cyl hd bolts 35 ft /lbs
and con rod bolt torques 5/16 " use 200 in/lb torque
or if 3/8 bolts use 300 in/lb torques
service manual is 92 pages long but helpfull
cheers hope it hepls
pauly46
May 03, 2011 | Cub Cadet Garden
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
