Question about Ertl 580 Super M Series II Tractor
2007 case 580 super m only 1000 hr no forward &no reverse pressure at pump 250 but in forward & reverse only 50 psi
3 Suggested Answers
SOURCE: case 580 tractor no forward
backhoe will not move forward
Posted on Aug 14, 2010
richroth
  • 9472 Answers
SOURCE: case 580 super e.
You are having the typical shuttle failure. There is a bellville type spring that returns the clutches when pressure is taken from the clutch pack. That spring will fail with time, it is nothing you did.
Posted on Aug 11, 2011
My 2000 dodge caravan won't reverse, how much would that cost, and what is wrong with it?
There are pressure ports on the side of the 4 speed under the solenoid pack. These are 1/16 pipe thread, with a gauge you could check each one.
From the engine towards the transfer gear cover they are:
Underdrive
Overdrive
Reverse
Lock Up Release
2nd & 4th
Low & Reverse
These ports are connected very close to the clutches, so a bad seal will show up as low pressure. in reverse, look for at least 145 psi in Reverse and the Low & Reverse ports at the same time.
If pressures are good here, you likely have a broken ring gear on the rear planet. This will fail and will still have forward gears as the ring is not used during forward movement.
Good luck, i hope this helps.
Jul 06, 2011 | Dodge Caravan Cars & Trucks
Case 580 super l stops as i drive it forward
What is the last thing that happened before you noticed there was a problem?
Jan 13, 2011 | Ertl 580 Super M Series II Tractor
I have a 580 super E it slips in forward gear but not in revers. this happened two times before and each time the filter was plugged with black material but after cleaning the filter it was fine. This time...
Was that the power shuttle that you broke down? If so, is it a Borg Warner velvet shuttle. I have a 580K and mine started slipping like that in forward and finally lost it completely. It had a strong reverse though.
I had to pull the power shuttle and replace the forward clutch disks. The stuff in the oil is probably the fibers from the friction disks. There are seven forwards disks and what happens in these shuttles is the Belville plate or washer breaks under stress and then wreaks havoc on the clutch disks.
What you are describing is exactly the way mine did. I put new forward dicks in and everything was fine then.
You said the disks looked new when you inspected them. You will see the reverse disks first and then as you go deeper into the shuttle you come to the forward disks. You may have been looking at the reverse plates.
My reverse plates also looked good but when I got to the forward plates they were burnt, scarred and very thin. Not much left of them. Check the forward disks, I bet that is where you will find your problem.
There are some pressure stall tests you can run to determine exactly what is not working properly.
Hope this helps and good luck.
Tim
Jun 18, 2010 | Ertl 580 Super M Series II Tractor
Ertl 580 Super M Series II Tractor Logo
98 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Are you an Ertl Toy Expert? Answer questions, earn points and help others
