Question about Canon FAX-JX200
Change Canon Fax JX200 from Auto print off to on
Please assist urgently to change the Canon Fax JX200 from Auto print OFF to ON
  • Anonymous Dec 02, 2008
    my fax is showing check 5100 pls help
  • Anonymous Mar 25, 2014
    receiving fax print having black horizontal lines
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
There are several ways in which Auto Print Off can be engaged, creating the situation you are encountering. It is important to remember that this function serves a specific purpose - to allow for documents to go into memory as opposed to going straight to print. This is often intentional, to save ink and reduce the actual usage of the machine; which will preserve ink and lengthen the life of the equipment, thereby reducing overall cost. Additionally, there are reasons this function is engaged without being purposely set by the operator, most usually in order to prevent loss of received faxes during the existence of some type of error condition.
To choose to receive faxes into memory rather than printing, this is most often done by pressing the on/off button quickly. It could be that you are inadvertently activating "Auto Print Off", if the on/off button was held down too long while turning the machine on. In the normal circumstance, to activate, you touch the on/off button to activate the function, and when you choose to deactivate it, press the on/off button again. Note that this touch should be brief, and not long enough to actually turn the machine on or off.
Along the line of conditions that cause Auto Print Off to activate without operator choice, there are several error states that invoke Auto Print Off. Primarily, these relate to: ink low/out, paper low/out, paper jam, or FINE cartridge issues. As any of these conditions could result in loss of a received fax, the machine switches to memory receipt in order to prevent such loss.
I would suggest, first, to make sure that when you turn the machine on, you do not hold the button after it has begun to start up. Then, if Auto Print Off is displayed (as it carries forward from the last ttime the machine was on), check the settings. Press [Menu], scroll with the up/down arrows to <Data Registration>, press [Start/Copy] and you will see <User Settings>. Use the arrows to select <RX Settings>, press [Start/Copy] and you will see <ECM RX>. Scroll again to <Option Settings>, press [Start/Copy]. Then, you will see <Off> if "Automatic Print Off" is activated, meaning the machine will not print (such as when ink is low), but will store the faxes in memory. Use the arrows to select <On> if you want the machine to print regardless of what it perceives the ink level to be. (Select <On> by using the arrows, press [Start/Copy], and then press [Stop] in order to exit the Menu listing.)
Now, if these steps do not resolve your condition, there could be a couple other issues. The FINE cartridge (ink) must be the specified Canon cartridge, and can not be reused. If the cartridge has previously been used, the machine will not recognize the ink level properly (such as when ink is manually refilled). It could also need cleaning, which is handled through the Maintenance menu. It is also important to remember a particular quirk of this machine, in that when changing the cartridge, you must make sure that paper is in the paper tray first. If all else fails, unplug the machine from the power source, wait at least 5 minutes and then plug it back in.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Aug 16, 2008
SOURCE:
NEED TO TURN ON AUTO PRINT ON CANON FAX -JX200
You can enable memory receiving feature temporarily.
1 Press [ON/OFF] to select .
􀁺 The fax starts receiving documents in memory.
􀁺 To cancel, press [ON/OFF] again.
If you would like for me to send you the user manual for the JX200, please send me an email to [email protected] Please put CANON JX200 MANUAL in the subject line and I will send you the manual right away. Lawrence Brown
Oct 11, 2011 | Canon FAX-JX200
FAX-JX200: I can not get AUTO PRINT OFF to turn on!!...
Press and release the on/off button....this will enable auto print. If you press and hold the on/off button...this will shut power off.
May 10, 2010 | Canon FAX-JX200
I have a canon fax jx-300. How do remove auto
Hey!Simply press the on/off button once and it will go from auto print off to auto print on!Good Luck!
May 03, 2010 | Canon FAX-JX200
How do i cancel auto print off? Fax-JX200
Press theon/off button once and it will go from auto print off to auto print on!Good luck!
Apr 16, 2010 | Canon FAX-JX200
Hi my canon fax-jx200 keeps coming up recorded in memory..How do I retrieve it?? Many thanks, Lorraine
Hi Lorraine,normaly with this fax it have a auto print off setting that keep the faxes in memory.You can turn auto print to on by pressing the on/off button once less than a second,then it will switch to auto print on.
Let me know if you dont succeed.
Dec 03, 2009 | Canon FAX JX200 Fax / copier Plain Paper...
Our Canon JX200 fax machine will send faxes but not receive faxes
Normaly it is the auto print off setting that is set to off,press the on/off button once less than a second then it will switch to auto print on.All the faxes in memory will be printed out.
Nov 30, 2009 | Canon FAX-JX200
Jx200 auto print off
press the on off button once.if you press and hold the button the fax will switch off,but pressing it once it switches between auto print off and on.
Apr 09, 2009 | Canon FAX-JX200
I have a canon fax jx500
Turn auto print on by pressing the on/off button once.If you hold down the on/off button the macine switches off,if you press it once it switch beteen auto print on or off.At first I was also confused by this setting.
Feb 12, 2009 | Canon FAX-JX200
Canon FAX-JX200 Logo
5,118 people viewed this question
Clive
Clive
old marine
old marine
Ekse
