Question about Canon PIXMA MP240 All-In-One InkJet Printer
I refilled my ink cartridge for canon mp240 but the black ink light is still flashing and I can't print. Ijust put ink in so i know it is full. How do i fix this problem
  • 106 Answers
Did you use proper ink?
Try to disable "check for ink level" in printer driver.
Then try to clean connector plate of cartridge and printer with alcohol.
Posted on May 19, 2011
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Pixma 240 refilled cartridge but printer flashes error and the black ink light comes on.
Try to press and hold the resume button for 5 + seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 05, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Will the canon pixma mp240 continue to print
you need to have both cartridges somewhat full to run, there is a initialization routine that the printer goes thru and if you don't have good cartridges with ink it won't let you print.
Aug 16, 2009 | Canon Office Equipment & Supplies
Black Ink has been re-filled, canon MP240 says its empty )=
i thnk you need to replace the cartridge maybe the ciruit has been destroy in the event of refilling the cartridge..so that the computer cannot read the ink level ..
I hope it help.
thanks for using FIXYA.
May 22, 2009 | Lexmark X3650 Printer
Canon ip 1800 refilled ink says ink has run out, it's full
Here's how to reset the printer so it doesn't give you the out-of-ink message:   1)  Hold down the flashing yellow RESUME button for almost 1 minute 2) Open the cover 3) Release the cartridge(s) (#30 is black, #31 is color), and then reinstall cartridge(s).  Close cover. 4) Turn printer OFF (I had to wait and try this numerous times as green light was flashing & it wouldn't shut off.  Wait, then press OFF again. ) 5) Turn printer back ON, and cheer when it prints.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Refill Ink Cartridges
First check the cartridge slots for spilled or dried ink. You can clean the slots with a tiny bit of alcohol on a Qtip.
Aug 22, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
324 people viewed this question
old marine
old marine
