Question about Gigabyte GA-8SIML Motherboard
Hi, my MB GB-8SMIL ver 1.0, I have install HD SATA 500GB hitachi on an add-on card, it only start, POST ok, cannot load Win Xp, even from CD drive and the screen become black. If Win Xp pass , cannot create partition. Thanks for help.
  • 106 Answers
Check power supply unit for +12V DC and 5V DC
Posted on May 19, 2011
Windows XP crashes with SATA HDD
If you go into the setup screen on start up. (BIOS) you will need to make sure that the HDD are set to AHCI this will allow your rives to exist together.
Feb 26, 2013 | Computers & Internet
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Motherboard specification not available.
Are you uning the recovery CD or a new OS?
A new Os (XP) will allow the second drive even if the old one will not. Of course you can always add a USB hard drive and a USB PCI card to make it all work. What are you using this pc for seems a little old for todays applications. Suggestion If your going to use this that you Replace the main hard drive with a 120GB or larger, new video card at least 256MB if not 512 and at least 1 gig of memory as I believe it will only take a max of 1 gig. you cannot use vista as it requires more resources than this Pc can give to support the OS. you may want to try XP LITE as well one you get XP installed to speed it up a bit!
Joe
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Can´t find SATA-disk on my motherboard MS-7061 and chipset KM400A
If the Bios does not see the disk, the operating system will not see the disk, nor will the install -even if you do an f6 to load drivers. It is most likely a problem between the motherboard not recognising the SATA-II interface. So no real solution I'm afraid. I suggest you install a SATA-II interface card which the BIOS will see, and add the card driver at f6 to install XP.
Apr 22, 2009 | Computers & Internet
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Gigabyte GA-8SIML Motherboard Logo
74 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
