Question about Briggs & Stratton Garden
I own an Ariens 1534 mini zoom. When pushing arm levers forward or backward, the mower jerks instead of moving smooth. The only time it moves smooth is when it is in really slow speed.
  • Jeff Ulman
    Jeff Ulman Aug 10, 2016
    Frame is broken by engine mount. Instead of propelling you forward it wants to go into the ground because it has no support. Ariens is a piece of junk. They don't stand behind their products.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Briggs & Str... Master
  • 1,303 Answers
That is normal you dont reve the motor on the car before putting it in gear
Posted on Apr 06, 2018
  • 49 Answers
SOURCE: Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Posted on Feb 06, 2009
  • 68 Answers
SOURCE: Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Posted on Apr 26, 2009
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
  • 246 Answers
SOURCE: John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 16 Answers
SOURCE: My riding mower workes fine fore about 45 mintes
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Posted on Jun 13, 2009
It will not go forward it is only 1 year old and yes it starts my husband past away and I don't know what I am doing wrong
After the engine starts you must put the mower into gear so that it moves. Look for the gear shift lever or whatever.
Aug 02, 2015 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Ariens Zoom 34 will not move forward or back
suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Nov 27, 2013 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Why won't my blades engage on my ariens zoom 1534?
take a look at the wires going to the clutch and make sure the wires where routed the right way and not rubbed against the belt and damage the wires
May 22, 2012 | Ariens 34 In. Zoom Series Riding Mower
Hydrostatic lawnmower doesn'i want to move
There will not be any actual adjust in the unit, there will be some adjustment in the rods from the hand/foot lever, if you can see the arm moving freely on the unit when you work the foot/hand lever it is probably not a linkage problem, if there is an external brake disc, make sure the brake is not binding, finally somewhere on the unit will be a bypass lever for push mode, make sure this has not been engaged.
Apr 25, 2012 | Garden
Tractor does not move
is the release lever in the neutral position the lever on the back of the tractor used to push the unit when not running then check the belt
Mar 31, 2012 | Garden
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens ezr 1742 will not move. everything works fine except it will not go forward or reverse.
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
Jun 07, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
215 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
